1 - 8 of 8 Posts
I'm about to replace the fender, grille, and trunk Hellcat emblems. I know the trunk and fender are stick on. Is there an alignment pin for the fender badges? I see a hole in the back of the emblem and thought that might be for an alignment pin. How in the world do you change the grille emblem? Any tricks on installing everything perfectly????
No pins on the fender badges. For the grill, that’s a little more involved. There is a push washer on the back that needs to be removed but if you have an once of sense and mechanical ability you will see what is required. Best wishes!
Do you come up from the bottom for the grille? I saw no access from the top. I may be missing that ounce of sense. Plenty of mechanical ability, though.
I am sure there is plenty of good threads on here or on YouTube. I was removing mine with no intent of replacing. I got lucky on the grill so just check out the resources and take it slow.
The front bumper has to come off
On my old Scat pack, I was able to pry (and consequently broke) the front emblem off.....but I don't advise that, as you could break/damage the grille.
And to get a new emblem on (with the press washers)....you'll want access to behind the grille, which you'll need the bumper off for
Getting the bumper off sounds hard/daunting, but it's not bad at all on these cars. (just trickier on the WB though)
2021 Dodge Charger Hellcat Redeye
If you have emblems already on and are just replacing them. Take blue painters tape and surround the current emblem on car and mark with a sharpie strategic points on emblem that you can line up with new emblems. I have done this on multiple cars including my charger hellcat and it was great.
I pulled mine straight off the grill, screw that anti theft washer..........Now can take it on or off with ease. Also cut that tab off as no need.
ALL badges should come in the trunk for NEW owner to install. As I dislike badges and stickers
Discussion Starter · #8 ·
Thank you all for your comments. The front bumper was removed and emblems were installed months ago.
1 - 8 of 8 Posts
