What do you think about this kit over other kits like Tapped, Gasohol, Firestorm
  • Like It
    Votes: 13 46.4%
  • Unsure
    Votes: 13 46.4%
  • No Way
    Votes: 2 7.1%
1 - 20 of 74 Posts
In The Market
Has anyone seen or is using this new Steve White Dual Fuel Pumps using the stock FP Basket. It appears it is using 450 pumps and is good for 1000RWHP on E85.
This would eliminate the 1/4 tank issues that the other kits have. Also this kit is selling for $1299.00
Link to YouTube Video
What are your thoughts
558643
In The Market
Discussion Starter · #6 ·
I was thinking the other benefits at that power level like fuel sloshing and possible fuel cut when the cars are tracked in corning. Of course the other benefit would be not worrying as much about finding a E85 station when your creeping towards a 1/4 of a tank. I would like to be able to extend the available miles to empty.
I think once you get to this "level", taking note to not run lower than 1/4 is a good idea regardless. With the FORE systems, you can run to 1/4, but they advise to not hammer it, which makes sense.
I found this out very quickly when I went to jump on the throttle with less than 1/2 a tank and went into what I call jerky mode very quickly. Keep it above 1/2 and we good.
In The Market
Discussion Starter · #10 ·
Well ended up going with Tapped Performance. Rick is now selling his kits with a fuel filter option.
I talked with Curt Dusterhoff about this setup and he said because they use 274 pumps it wouldn’t be enough fuel if going flex fuel just so you guys have a heads up. I love the idea of them using the stock cup but those pumps aren’t enough. Tapped at least uses the 295 pumps now
2018 Challenger Hellcat
Thanks for heads up. I never did get it because I thought the price was little high. Would love someone to come out with something similar or even better a mod for whatever current pumps your using.
I run the Tapped setup with Holley hydramats. Never had an issue, but I still try to keep the fuel level above 1/4 tank anyway.
Sent from my KB2005 using Tapatalk
I was going to swap out to Hydra mat but Rick at Tapped advised against it, said it lowers pump out put due to being a suction restriction? I’m at the hairy edge of dual 285’s keeping up so I took his advise and treat 1/4 tank like empty as far as hammering on it goes. But I’ve run the tank down to empty normal driving to which it took 18 gallons to fill and fuel pressure never wained. I do know/have learners first hand though to treat 1/4 like empty as far as flooring it goes, it does suck air and lead to a fuel cut.
This is by far the most superior product out right now.
R.K.
I’ve not read many, if any, posts on anyone who has used it or it’s dual 285 first offering?? I’ve liked it since first seeing it because of its use of the continuous circulation basket but have yet to converse with anyone who has used it, ie I don’t want to be the guinea pig. I wonder if they’ve incorporated a check valve into it somehow as the Ti295’s don’t have internal check valves which causes issue in trying to start the car as the fuel pumps only run for a second or two on key on and fuel pressure goes up and drops right back off to nothing without a check valve. A buddy of mine just went through this with a dual 295 Fore setup and he had to add an external check valve to get the car to start reliably.
That youtube guys with the red Hellcat has them installed. When I talked to steve white, they sold a ton of them locally. I'm sure there are a lot of people that don't care to post on the forums. But having the stock basket is a huge plus.
R.K.
1 - 20 of 74 Posts
