Hey guys, was scrolling the forums and noticed this thread. Here is the deal with the Steve White Dual 295 pumps ..... THEY ARE AWESOME.
As you may or may not know I have a Twin Turbo hellcat build running a steve white 426 forged hemi on his pumps that I've dyno'd up to 1250whp. I also run all fuels from 93 to E85 to leaded 116 so my experience should cover each option.
On 93 octane I can run upto 15lbs of boost which makes 950whp and pumps hold steady at 80-85psi up to 7100rpm.
On E85 I can run up to 20lbs of boost which makes 1100+ whp with the pumps holding at 80psi upto 6500rpm and by 7100rpm dips to 75psi.
On 116 leaded race gas I have been up to 25psi which makes 1250+ whp with the pumps holding at 80psi to 7100rpm.
I run ID1300 injectors in case any of you are wondering with loads of duty cycle left.
So what I found is if I want to make more than 20lbs of boost I CANNOT use E85 because they start to loose pressure at high RPM fast. That's fine for me because for those high boost runs I simply switch to 116 race fuel and all is well. I will try 27lbs of boost soon see if the pumps still hold the pressure at 80psi.
You should use my boost numbers as a reference although with supercharger you will make less power. Use those boost numbers to know the limits of the fuel system.
Best benefits, no more fuel starvation under a half tank and I didn't have to spend $3200 bucks on the Fore triple system with that tedious install time....
