The pumps have the same filters as the stock pump. There is nothing else required. They are E85 ready.Does the SW have a filter for E85 applications? I understand a filter is good insurance regarding E85's impurities(?).
Tapped Performance offers a plug and play after the pumps filter solution. I use the one with the 5 micron microglass filter element. Works with any pump system as it’s spliced in the fuel line under the car. Every injector company recommends filtering E with a fine filter. Here’s mine installed.Does the SW have a filter for E85 applications? I understand a filter is good insurance regarding E85's impurities(?).
Fore site says not to use on returnless systems, unless you have a pressure release valve. FCV Check Valve (foreinnovations.com)Just put it in run, wait 3 seconds then hit start, should be fine that way. If it gets annoying a Fore check valve can be put in the line right after the filter assembly. It’s a bigger check valve then used in the pumps so it doesn’t cause much restriction.
That is correct. I found this out after phoning Steve White.Learned that the SW pumps dont have an Anti Drain Back Valve. So youll have to prime the pump in "Run" for a few seconds before cranking the engine.
This allows the unit to be 1050LPH.
All based on your tune. Ask your tuner that kind of question.So what happens, if anything, to.performance when E85 is more like E80?
Luke himself said dont try to start right away or itll just crank alot longer. He said give it a few seconds (unitl the pump stops priming, youll hear it) then turn it over. Hey if it doesnt need it then great, I was gonna wait on a Fore FCV to see.There is no difference in starting the car with these pumps even tho they don’t have check valves. I start my car normally just fine. No priming.
Rick tapp himself said it’s not an issue when I was inquiring about this same topic. My car fires up right away just like it did stock.Luke himself said dont try to start right away or itll just crank alot longer. He said give it a few seconds (unitl the pump stops priming, youll hear it) then turn it over. Hey if it doesnt need it then great, I was gonna wait on a Fore FCV to see.
Will E content vary from brand to brand (Shell, Chevron, Sunoco) or is it all the same tanker of E?
