1 - 7 of 7 Posts
Mickey Thompson P305/35R20 ET Street S/S Tire (3402) 90000024578
Brand new in boxes - never mounted.
$700 - Rochester, NY - pick up only.
Part number : 90000024578
Weight: 34.00 LBS
Min. Wheel Width: 10.00in.
Max. Wheel Width: 12.00in.
Black Sidewall
Directional Tread Design
Tire Size: P305/35R20
Specifications:
Section Width 305
Aspect Ratio 35
Tire Diameter (in.) 28.7
Wheel Diameter 20
Tire Size 305/35-20
DOT-Approved Yes
Tread Width (in.) 10.98
Tread Depth (in.) 6/32
Speed Rating N/A
Maximum Recommended Wheel Width 12 in (304.8 mm)
Minimum Recommended Wheel Width 10 in (254 mm)
Maximum Tire Diameter 28.99 in (736.346 mm)
Minimum Tire Diameter 28 in (711.2 mm)
Manufacturer's Part Number: 90000024578
Discussion Starter · #6 ·
No longer need them or the other set mounted to the wider PK rims.
Car was stolen and don’t need to replace it with the known anti theft issues.
I buy two sets for the season
1 - 7 of 7 Posts
