Where to get an oil filter wrench that fits the bottom of oil filter for 2021 hellcat. thank, Larry
Local Advance, Autozone, etc...Where to get an oil filter wrench that fits the bottom of oil filter for 2021 hellcat. thank, Larry
Thanks, just ran up to Lowes bought a 93 mm 15 flute 1 piece aluminum Craftsman filter removal tool $9.98 , hopefully its not junk as the factory filter is sometimes very tight, anyway, just rounding up some things to do my first filter change, not sure when I am going to do it as it only has 108 miles on it, just picked it up a few days ago.Local Advance, Autozone, etc...
Cool. Respect the break in period then let her rip!Thanks, just ran up to Lowes bought a 93 mm 15 flute 1 piece aluminum Craftsman filter removal tool $9.98 , hopefully its not junk as the factory filter is sometimes very tight, anyway, just rounding up some things to do my first filter change, not sure when I am going to do it as it only has 108 miles on it, just picked it up a few days ago.
I will look at that wrench thanks, larryJust wanted to add, you might run into a situation where the filter is on so tight that a 15 flute filter socket doesn't work (mine spun on the filter even with the exact 93mm 15 flute cup) I ended up using a Lisle oil filter wrench, and it came off without any trouble at all. This is the wrench I used:
Lisle 3/8" Drive Oil Filter Wrench 3-1/8" to 3-7/8"
Just ordered that Lisle #63250 oil filter tool, just gathering some tools to do my own oil changes, it might be a while got 108 miles on it now, just watched a guy on u-tube do a oil change on a redeye looked very professional but he didn't drain the oil cooler, this is why I feel I got to do my own, who can you trust,LarryJust wanted to add, you might run into a situation where the filter is on so tight that a 15 flute filter socket doesn't work (mine spun on the filter even with the exact 93mm 15 flute cup) I ended up using a Lisle oil filter wrench, and it came off without any trouble at all. This is the wrench I used:
Remember to remove the plug in the bottom of the side of the oil cooler to drain THAT oil, also, Larry.Thanks, just ran up to Lowes bought a 93 mm 15 flute 1 piece aluminum Craftsman filter removal tool $9.98 , hopefully its not junk as the factory filter is sometimes very tight, anyway, just rounding up some things to do my first filter change, not sure when I am going to do it as it only has 108 miles on it, just picked it up a few days ago.
