1 - 11 of 11 Posts
Stock for now, 2016 SRT coupe
I have a stock, 2016 Hellcat coupe. Wanting to put the MT/ET next. Do I need a wide body kit to accommodate the MT? & if so, can I use my stock rims?
Thanks.
I've seen people stuff 315's in a NB but many of them report having to tweak some things to make them not rub.
You have to start with the correct offset rim for one thing.
Possibly spacers and minor wheel well adjustments. Don't know if they had to roll the wheel well lip with the baseball bat trick.
It depends on the specific tire too as well as the size.
I have Challenger 11x20 rims +25 Offset repo Brass Monkeys and 305 Continental Extreme Contact summer tires and I need a 3MM spacer and it rubs ever so slightly on occasion on the inner wheel-well, 5MM spacer eliminates the inner WW interference but it sticks out a smidge. both work but I may bash the bump in the front inside rear wheel-well when I put them back on in the spring with a 3MM spacer.
· HOTY Winner
There is nothing to roll on the rear of a NB Challenger.
· HOTY Winner
This is a 17x10 with a 315 on a NB
Tire Automotive parking light Wheel Car Vehicle
Wheel Car Tire Vehicle Cloud
Reactions: Spartacus
Maybe not, I believe you.
I haven't looked at the wheel wells in my car that close.
Would be cool if I could stuff 315's in the back (2016 HC Challenger NB).
I was thinking 20x10.5 or 20x11 new rims, but that's probably a bit much.
May just go with a 305 tire on a 20x11 rim.
Very nice setup on your car.
Did you have to change brakes in the back to run the 17's?
What 17" rim is that?
What are you running in the front, stock 20's?
· HOTY Winner
Hi,
Thanks!
Stock brakes, but shorter bwoody greasable sway bar end links.
Forgestar F14 beadlock 17x10.
Stock 20s on the street, 18x5 f14 front skinnies for strip.
The rear has nothing to roll or you would be rolling the exterior 1/4 panel and cracking the paint. This is the widest you can fit with some minor modifications.
Take care
1 - 11 of 11 Posts
