1 - 8 of 8 Posts
I was detailing my car the other day noticed the corner of front part hood seem to be bumbling up in multiple locations. These hoods are aluminum so found it strange. I would assume water is getting in between the heat extractors. Dealer said it common.
572955
572956
572957
2016 Bright White Challenger
Dont you carry a rust warranty?
Or do they not consider this rust...
Same as the corrosion that occurs under the hood around the hood latch - it should be something they fix without too much fuss..my scat packs hood was replaced a few times LOL.
Discussion Starter · #8 ·
I also had rust comming through on that beem that goes across the engine bay in front of the wiper motor assembly. Not sure the name looks like a strut brace....
1 - 8 of 8 Posts
