1 - 6 of 6 Posts
Hi,
I am continually getting a P0171 error, left bank lean. AFR gauge reads fine, around 13.5. Yes I have upgrades including 1050 injectors and Magnuson Blower. I have had the O2 sensors replaced under a recall, no change. I have swapped out all MAP sensors. The pressure sensor on the intake hose threw a code, replaced it. It was intermittent now comes back after right resetting. Fuel pump maybe. Guess I could find a gauge and try checking, what pressure sjould I see?
Thanks
Try clearing the error and then drive it slowly around town and see if the code comes up again. If not, then give 'er the beans and see if that sets the code. Could be a bad injector (or missing or folded o ring). Check and reflash the tune.
And you had a bad pressure sensor?
Recheck that for correct part number and function.
I threw a code on the one on the intake tube but cleaned it and it went away. I decided to change it just the same. I can get my friend to check the injectors, as I have a really hard time getting them unplugged I did pull the fuel rail on that side and had to replace an o-ring that i messed up. :(
1 - 6 of 6 Posts
