1 - 20 of 30 Posts
Challenger SRT Hellcat 6MT
After seeing reports of Hellcat theft, I decided to have Ravelco installed. Not exactly cheap, but seems to be a good way to make it more difficult to steal the car (of course, you can still flatbed it).
Anyway, on the first drive from work I got a "Check Engine" light and the P0452 code thrown. Never had any issues with this car whatsoever, and now this... The fuel cap is tight and looks like new.
If Ravelco messed up wires/connections, it is going to be a nightmare to fix...
Any ideas while I'm waiting for a reply from Ravelco?
P.S. The Ravelco installer says that they didn't touch anything related to that system. A coincidence... Well, yeah, I'm sure they didn't touch that system intentionally. I'm less sure about them pinching or shorting something unintentionally... Well, I'll start by getting a new fuel cap, and I'll go from there...
2015 Charger SRT Hellcat
Does become a challenge to "lay blame" where it is suitably convenient when in reality it may be coincidental that these integrally computerized systems just throw us weird stuff when the pcm does not detect responses or voltages in the range that is created.
You did the right thing to contact Ravelco right off. Only time I have had issues was when I tried to start the car after it sitting for like 3 weeks shortly after it was installed and I forgot to plug in the module. threw all sorts or codes at me and then the realization hit me.....derp
I don't think it's supposed to throw a code that won't allow a car to pass an inspection if the owner forgot to use the plug. In fact, they demonstrated how the system works by pulling the plug while the motor was running.
In any case, while the Ravelco Installer's first reaction was "It simply cannot be related to the installation, just a coincidence", this morning I have received a text from them asking to schedule another appointment to "switch one of the Ravelco circuits". After reading what else they say I conclude that different model years may use somewhat different "PCM logic", and that they did something that does not mesh well with the PCM of my car. The good thing is that it looks like they have the documentation and the expertise to figure it out, and intend to rectify the issue. I'll update when an update is available.
· Have Guns Will Travel
2019 Challenger SRT Hellcat Redeye - 2015 Challenger Hellcat
Have you tried resetting it?
No. Even if it helped, it wouldn't be the proper operation of the system. So I'll leave it to them to figure it out. The driveability of the car is not affected by this code, so I can use it in the meanwhile.
Believe it or not the dealership will do the same thing so....
Discussion Starter · #7 ·
Clear the code? To have it reappear some time after an attempt to start the car without the plug? I'll let Ravelco fix it the right way.
BTW, I cannot image what kind of fun it would be to try to figure it out at the dealership (who doesn't know what exactly Ravelco did)...
Emissions bs I believe.
Tony is correct..
P0452 stands for “Evaporative Control System Pressure Sensor Low Input.” This code is set by the car’s primary computer (often referred to as the powertrain control module or PCM) when the EVAP sensor detects changes in pressure that are below specification. The PCM will trigger a P0452 when the sensor signal falls below a certain threshold for a specific amount of time.
Sent from my SM-G781V using Tapatalk
Discussion Starter · #11 ·
This is a generic description. More specific is below:
Font Document Number Terrestrial plant Screenshot
If you read it, you are going to see a reference to a timer. My installation of Ravelco shuts PCM off when the plug is pulled, this stops the shutdown sequence before its completion. After two cycles this generates the P0452 fault.
Again, this is for my specific installation. Yours (if it works properly) is most likely different. In any case, this should be easy to rectify.
2022 SS, 2020 1320, 2019 HC-Sold, 1967 Camero SS, 1971 Charger Superbee
Good deal, I'm getting mine down to Vegas to get one installed as soon as I get a break in work. They seem like a great group of people that really know their stuff. Getting my F450 done also
· Super Moderator
Check put this thread @fnkychkn doesnt come around much anymore.
But his info was always great!
Linda :)
Having installed my own Ravelco following their directions, the emission is never touched. Your problem is in now way related to the installation of or the Ravelco in any way. It’s something else causing it.
1 - 20 of 30 Posts
