Have any of you had this code? From what I've found it is in the pcm. I dont think its in the tune because I have tried a few different tunes and it will go into limp mode on all of them.
It started when I put one of the old tunes back in that it used to run all of the time. Was driving normal and all of a sudden the repair stability control lights came on and then it went into limp mode. always able to shut it off and restart it and it runs fine. It is an HP Tuners unlocked pcm. Also is it possible for a bad pcm to change tune parameters at any time?
Thank you in advance!
