1 - 7 of 7 Posts
anyone have this and figure out what it was I have a 2.85 Pulley ID 1000s NGK 2309 1 Step colder plugs and intake with catless mids but don't know what could be causing it
Banned
I have a 392 and got code P219B, which is the “Air/Fuel ratio imbalance” code on bank 2.
P219A is on bank 1.
I had to chance camshaft and rollers. One of the lobes on the cam was totally worn out.
For you, it could just be a bad upstream oxygen sensor, or clogged injector.
Good luck!
Discussion Starter #3
I literally just changed them before the check engine light came on though because my tuner told me too I know they are under warranty I'm assuming change them again and see if it comes back on ?
Discussion Starter #5
My injectors we just flow tested maybe 2000-3000 miles ago and upstreams were changed 500 miles ago but they have a warranty
1 - 7 of 7 Posts
