So these fit without any modifications? Also what would the widest tire you would recommend running with these wheels?Oh most definitely Widebody Challenger or Widebody Charger, same fitments, We have sold them for both.
No modifications needed I run 315/50/17 look the best on widebodySo these fit without any modifications? Also what would the widest tire you would recommend running with these wheels?
thanks.
Correct aside from short end links or compressing the rear suspension you are good to go.No modifications needed I run 315/50/17 look the best on widebody
thanks.
Unfortunately those 17x11s are Widebody fitment only, 17x11 will poke about 1.5" or so. Designed to sit flush with Widebody fenders.@[email protected] can you confirm these 71HB7110W62A would fit the rear of the standard bodied 2015 HC Challenger? I’d much prefer 11 wide over 10 with a M/T 305 45 R17. Thanks.
On my 2018 charger I ran 315s without any issues. So I need to install shorter rear swaybar links to make 315s w/17” wheels work on my 2021 widebody redeye. I’m currently running p zero summer tires that are 315/35/20s without any issue On all 4 corners
Sounds good! It may work out for you then.Thanks for the quick reply @[email protected]. I’ve got the Phillips Lil Devil fender flares on my car so they do extend out a bit. I’ll have to check into it a little more to decide. Thanks again.
Just wanted to let you know those 17x11's should work with the Phillips flares. That offset is actually 1.3mm less (inward) than what Phillips recommendation is for their 11.5" wheel and 335 wide tire. However, if you're planning to run a 315/50/17 it may rub the outer lip/flare if you're lowered at all since it's a tall tire. If you're on stock springs it should be just fine.Thanks for the quick reply @[email protected]. I’ve got the Phillips Lil Devil fender flares on my car so they do extend out a bit. I’ll have to check into it a little more to decide. Thanks again.
@HellcatMatt Great info thanks Matt. So if you think I can get away with the 315 then the 305 on the 11 inch wide rim should be a bunt. Btw, the car is stock height on stock springs.
[/QUOTE
I certainly would do the 315's, I think they look so much better. If you go that route, I'd love to see some pictures. I'm waiting on my Phillips flares and I'm changing a couple different wheel setups to accommodate them as well.@HellcatMatt Great info thanks Matt. So if you think I can get away with the 315 then the 305 on the 11 inch wide rim should be a bunt. Btw, the car is stock height on stock springs.
