1 - 20 of 26 Posts
2019 Redeye
my Race built blower from FAS Motorsports will be here this week,
I ordered the top lid in white. It won’t be here until Friday but the pics look great.
I will post pics when it gets here
2022 Hellraisen SS
Discussion Starter · #7 ·
No that’s a factory lid. Just powder coated
I think it was 150.00
the snout and blower section are all polished, ported with ceramic bearings and clearanced.
was it hard to take apart? I want to restore the factory finish, I rubbed some off with goo gone trying to get the sticky stuff ftom sticker.
Chris, I had the same problem with the sticky stuff and rubbed some finish off.
I used a high heat paint and it actually turned out good.
Pulling that lid off isn’t hard, but, you have a sensitive paper gasket and all the bolts have a torque pattern.
You might try the high heat paint first. If you don’t like the outcome, pull it.
2022 Hellraisen SS
Discussion Starter · #10 ·
what paint did you use?
I agree, if you want to take the SC off.
I wouldn’t do anything but powder coat. Way more durable for the environment it’s being used in.
paint will work but won’t stay pretty as long in the heat. I know the heat paint will work for you but powder coat is alwa my 1st. Choice for durability
just my .02
'23 Redeye Jailbreak
I dropped a Dremel on my thermostat housing on my purple Hellcat. Said Dremel was locked to on (I was polishing the coolant lines). It gouged a nice scrape in it, similar to what you have here on your SC lid. I fixed mine with shake paint and a coat of shake paint clear coat. It looked like nothing ever happened. You could do the same thing to this one, but as I mentioned to you in DMs a few days ago, I would worry about it "baking" into a different color as that SC gets HOT.
1 - 20 of 26 Posts
