1021 - 1040 of 1056 Posts
Discussion Starter #1,021
Yes that's a dent in the mid pipe . That happened when I broke my driveshaft. I'm also keeping the active exhaust valves. I like the mellow sound when cruising around town .
Discussion Starter #1,022
I have a few different mufflers to try also .
Flowmaster FlowFX
Flowmaster super 40
Dynomax VT
Dynomax ultraflo .
Discussion Starter #1,023
Well I got phase one of the exhaust on . Im starting with the flowmaster FX muffler . I'm torn with the flowmaster super 40 mufflers . They sound great but don't flow very well . The dynomax VT mufflers have a 3 inch inlet/outlet but necks down to almost 2.5 in inside . I'm very disappointed with these mufflers . I have dynomax ultraflo's on the shelf for a future test . Unfortunately I don't have a hoist and do everything on Jack stands . I'm going to visit a friend with a hoist so I can inspect the system and re-tighten all the clamps and check the alignment of everything. I couldn't get everything to 3 in or larger . The smallest joint is about 2 15/16 . When I get the mid pipes and X pipe ceramic coated I will get an exhaust shop to bump it up for me with a hydraulic tubing expander . I will get some better pics when it's up on the hoist .
Btw I actually think the car is quieter inside at idle and low speed driving and doesn't have that "crackle" and more when letting off the throttle.
Looks pretty cool and nice job!! I did the 3 inch cat back straight and didn’t think till now but I haven’t noticed any poping either
Discussion Starter #1,038
I believe the stock exhaust system is meant to work together from the stock manifold back to the tips and once you change one item it throws the whole thing off .
That's a shame. Be sure to set those mids aside for me when the long tubes arrive. ;)
Discussion Starter #1,040
Lol no problem.
Yeah the full stock exhaust sounded great but I find once you change 1 piece in it then it throws every off sound wise ( sound is subjective) . I now have the stock manifolds , stainless works catless mid pipes and a 3 in flowmaster exhaust. I went with the FX series exhaust because I wanted to keep the active exhaust and the FX mufflers flow better then the chambered mufflers. The only modification I did was where the flow master X pipe was crimped down to meet the factor 2 3/4 mid pipes I expanded it back up as much as I could and it's about 2 15/16 . When i do the long tubes I will get a better pipe expander and get it up to 3 in ID .
I must say the flowmaster pipes really tuck up under the car nicely . I'm going to get some pics as soon as I can get it up on a hoist .
