Hi all,
Is anyone pulling a fuse or 2 as antitheft device when parking in an exposed area?
Anyone know which fuse(s) to pull?
2015, SRT392 Charger
Thanks
Well, if you need to pull them 5 times a day, I'd just move or sell the car.......... 💯Yes fuel pump relay. I believe it's in the rear fuse box.
My concern with pulling out the fuel pump relay fuse from the fuse box might weaken the connectors over time causing it to become worn out/loose?
I'm not sure if there designed to be pulled out and put back in multiple times
Yep.Just put a kill switch on it and forget about the fuses.
Find the wire going to the fuel pump relay and add a simple on/off switch in a concealed location. Very simple task, just takes a little research and very little effort. Cheaper and only you will know the location of the switch. Why complicate things with a kill switch or complicated systems.
You just defined a kill switch. lol>Why complicate things with a kill switch
That's a kill switch.>Find the wire going to the fuel pump relay and add a simple on/off switch in a concealed location.
You're right, eventually he will screw up his fusebox.Yes fuel pump relay. I believe it's in the rear fuse box.
