Push pin Rivet part numbers and links ( Pushpin )
9082 Views 12 Replies 7 Participants Last post by  BULL
2
While I believe this information to be reasonably accurate, I haven't actually ordered or vetted the information in this thread, proceed with caution.
I will update as members give more info and feedback.
Chrysler # 6503598
Used to hold air splitter in place among other things...
Also some locations inside front fender well
8mm hole, 20mm head, 25mm length(?)
Amazon.com: Chrysler Push Type Retainers Clips (Chrysler # 6503598) - Package of 20: Automotive (Mopar)
Amazon.com: GOOACC Nylon Bumper Fastener Rivet Clips Automotive Furniture Assembly Expansion Screws Kit Auto Body Clips 8mm - 40PCS: Automotive (3rd Party aftermarket)
Amazon.com: Chrysler Jeep Dodge Automotive Push Pin Rivet Mopar OEM: Automotive (HORRIBLY overpriced - EACH!)
(Reference) Oil Change Push Pin / rivet
Chrysler # 6506132
Amazon.com: Chrysler side Radiator Shield Push-Type Retainer (Chrysler # 6506132-AA) - Package of 24: Automotive (pkg of 24)
20 Side Radiator Shield Retainer 6506132-AA Fit Chrysler Sebring Stratus 20x17mm | eBay (ebay)
Other references:
Larger bolt to hold on lower, rear shield under engine during oil change
6508332AA
Under-Body Shield Screw - Mopar (6508332AA)
Still looking for p/n for smaller bolt?
http://www.hellcat.org/threads/lower-push-pin-part-number-for-belly-pans.5892/#post-145696
SRT_HC_707
1 - 13 of 13 Posts
I know there is a proper tool for removing the push pins instead of using a flat blade screwdriver. What is the proper name for it?
Not quite what I remembered, I got this for some work I did on our Durango... (and the main tool is for a different type of rivet from above...)
AFA Rivet Gun - For All Plastic Rivets - Free Fastener Remover Included - - Amazon.com
There we go, that's what I need. I'll look on amazon.ca and try to find one, local parts store would be another option.
I have a couple I got from AutoZone. The tool is easy to find.
I picked up a package group of plastic tools from Harbor Freight, with slots that fit under the pins for removal.
There are cheap and work fine.
Here: Nylon Pry Bar Installer Kit 4 Pc
I have a couple of different sets like that as well. They're not bad except they don't work inside the recessed holes of the shields (they're too big/wide and don't have the high angle needed...)
As usual, great find. Just happened to be what I was searching for today as I broke one of the push pins.
Will that tool fit the recessed clips in the front engine shield? Those are a bear to get at.
While it does fit, the angle isn't as sharp as it could be...
Still, it works better than any other one I've got.
Thanks, maybe you could bend in a vice?
Exactly, but I want a second one first. I just keep forgetting to pick one up....
1 - 13 of 13 Posts
