1 - 20 of 27 Posts
Just a heads up and to bubble this topic back up, I just ordered a 7000LT on Amazon. It's $1815.00 less $150.00 instant coupon and free shipping. Ordered Saturday morning, ETA is 4/6 to my house per Fed Ex. I like this deal because the 7000 can handle the Challenger for sure but it can also handle my other vehicles with ease.
Discussion Starter · #2 ·
Here is the link:
.2020 HCNBM6. ...2022 RENB...
Discussion Starter · #5 ·
Those are so cool. Definitely on my buy list once I buy a home (hopefully next year)
Discussion Starter · #8 ·
I thought about those but I was like why spend 2k on a quick jack that goes 2 feet off the ground when I can get a 4 post lift for like 5K and lift one vehicle and park another under it and not kill my back working under a car. whatever you have room for I guess
Yeah I would go the other route if I had space. I decommission offices for a Fortune 500 client and have given about 2 dozen car lifts that had been used about 5 times away for free around the country.
Got mine for Fathers Day last year. Ordered through Home Depot as they had a big sale. They work great! View attachment 591310
Yup. Same here. Paid something like 1200. I was going to go with a 4 post, and actually had my garage built to 13’6” but decided Ill probably be moving within the next 5-6 yrs I didnt want to leave it for the next guy.
Tire Wheel Car Vehicle Hood
Motor vehicle Vehicle Car Automotive tire Automotive lighting
Reactions: mrl859 and Mattm400
Get both. The QJ is good for tire changes, 4-post you need a trolley lift. Also good to hose off the salt in the Spring outside of the garage.
I have 1 too, the new model 5000 tlx, 3” taller and extended. I’ve never disconnected the lines with it raised up, how hard is it to reconnect the lines once it’s up and you disconnect them?
Piece of cake. I always disconnect and store the lines away off the ground, unless I'm just going up and down.
Reactions: Unholy707
I’m using the oinc
Are you guys using pinch weld adapters? I can't figure out good contact points on my Durango. The pinch weld points are WAY up inside the side skirts.
I’m using the pinch weld “blocks” that you can get off Amazon that bolt to the pinch weld and you keep installed. I would use something like that and the “truck” kit that quick jack sells
1 - 20 of 27 Posts
