Has anyone with a cat delete put a zinc oil additive in their 'Cats, or used an additive like Rev-X Racing oil? Or is that just overkill, do you think?
Summit carries the Rev-X line.
Too much "zinc" (as in ZDDP) can actually lead to increase in wear. The excessive ZDDP forms a glass like coating under heat and pressure and then when this glass coating breaks ups it "plucks" grains of metal from the surface. This can lead to less the optimum surface conditions which leads to a break down of the oil film that would normally exist and prevent metal to metal contact.Has anyone with a cat delete put a zinc oil additive in their 'Cats, or used an additive like Rev-X Racing oil? Or is that just overkill, do you think?
What do you use, if you don't mind my asking?I have used an additive in all my vehicles since the day after the oil got crappy on us
I don't think anyone sees the need for running *excessive* amounts. I know I don't. Rather, I'm looking to optimize the blend, if possible.I see no need to run excessive amounts of ZDDP even if one doesn't have converters installed.
Rex-X was nano boron based as discussed above...at least it was years ago.Rev-X has a special Zinc additive for flat tappet engines. If I'm remembering correctly, the Penzoil Euro Synthetic had more ZDDP than the ultra platinum, but don't quote me on that. I am curious to know, though, what the additives are in special race oil treatments. For instance, Rev-X Race oil additive notes that it uses "no graphite, moly, teflon, acids."
Right, a ton of old cars that had rebuilt engines have lost them due to lack of zinc and phosphorous. I have seen it. It destroys lifters and cam lobes. Don’t waste your time worrying about it for newer vehicles.Yes, fully agree - it is critical for flat tappet cams, not so much for roller cams, and too much additive is not necessarily better for street applications. I use RedLine (also have the Lucas equivalent on the shelf to try in the future), and use only enough per their mixing chart on the website to try and achieve what the good oils had prior to the zinc and moly being severely reduced. This works out to approx. 1/2 bottle for typical street car oil capacity 5-7 qts, and I used a full bottle on my dually Ram CTD that had 11 qts capacity.
My info is ZDDP was initially seen as a way to reduce lifter/cam lobe failures which over time proved to be due to not insufficient ZDDP levels but instead lousy cam/lifter metallurgy/quality control.Right, a ton of old cars that had rebuilt engines have lost them due to lack of zinc and phosphorous. I have seen it. It destroys lifters and cam lobes. Don’t waste your time worrying about it for newer vehicles.
I saw it happen with high quality Lunati and Comp cams.My info is ZDDP was initially seen as a way to reduce lifter/cam lobe failures which over time proved to be due to not insufficient ZDDP levels but instead lousy cam/lifter metallurgy/quality control.
Pretty sure the owners manual tells you not to use them. Why would you??I must confess I believe the majority of additives are snake oil. However, with that said, I would say two I have run across have some potential merits:
1. Hy-per lube zinc replacement additive. Polymer based and plays nice with Zinc additives. Know a chemist who developed it. Have not used yet, but have some for next oil change in Hellcat.
2. Archoil 9100. Used in my 6.7 Powerstroke Diesel, Onan Diesel generator, and my 2012 Mazda CX-9. Seat of pants makes the engine sound and run a little smoother. CX-9 UOAs did show some lower wear with vs without additive, but honestly not sure if lower engine wear is because of it. Don't have 1,000s of UOAs with or without to prove anything either way.
Just my .02 cents...would start there. Hard to prove these additives work or not. YMMV.
