Looks Great ! What were the 2 plugs that you tapped into? example: Color of wires
Pink, positive and black, double check with voltmeter just be sureLooks Great ! What were the 2 plugs that you tapped into? example: Color of wires
I just bought an Escort Redline and the direct wire power cord. My HC is a 2017, currently in transport to my dealer. Having never owned one I assumed the fuse box was in the cockpit! The cord I bought is intended to be wired into fuse box. Do you think that I can use it to tap into the mirror?View attachment 47177 View attachment 47169 Installed my escort max 2 using the Blendmount and MirrorTap, went pretty good, took about an hour, little nervous, did not want to break anything, but thanks to info on these forums all went well. Also got my vanity plate, submitted a list of five that I wanted, this was last the last one, still happy with it
OK thanks. I'll go ahead an order one of those.Fusebox unfortunately is not in the cabin....I do not believe that will work unless you pull apart your car to get to a wire...like this guy did: Hellcat Valentine 1 Install (BlendMount / HardTap).
.......not worth it with the available option of a mirror tap.
If you have a challenger like me ...I believe this is what you want....POST #5 above.
This is what I ordered...waiting for it to arrive then I will install.
Good luck per that webpage this is the one they recommend. This car is so new I guess that this forum does not have many DIY threads. You have to search and try to piece together information from multiple threads and then make an educated guess on everything....OK thanks. I'll go ahead an order one of those.
Well said!Good luck per that webpage this is the one they recommend. This car is so new I guess that this forum does not have many DIY threads. You have to search and try to piece together information from multiple threads and then make an educated guess on everything....
The good news the car is so perfect OEM that there is not allot to do other then routine maintenance etc.
