1 - 4 of 4 Posts
Radio stopped working in my cat it's on but does not work. My car is stuck on track mode none of the srt functions are present. Took it to the dealer they did a complete reprogram. Got the radio to work (play music of which it did not before), got the SRT functions to come back on the screen but now they do not work, in the bottom left corner it says "none set-up" and for example when you click on custom it states not available in none set-up mode. Yes that is right it says "none" not "non". Can anyone give any advice?
Personally I had the radio in my 2018 Hellcat go bad. The NAV system went wonky.
Long story short dealer tried not one but two updates -- factory updates not yet available from the uConnect update site -- neither of which helped. New radio ordered and week or so later it was installed. NAV worked just fine after.
There have been some reports of after an update the radio taking time to normalize/stabilize. My Hellcat received at least one over the air update and my Scat Pack likewise and I never noticed the radio acting up upon the next engine start after the update was applied.
But you can give the radio time.
Oh, last but not least I did notice some odd radio behavior which proved to be insufficient use of the vehicle. These Hellcats do not like to sit around too much. I have not bothered to check but I suspect even shut off the car has a larger the normal amount of current draw which can cause a problem. Upon engine start the voltage dips severely which can "glitch" the radio. While the engine starts ok -- but with just a hint of some slow/delayed cranking -- the voltage dip causes the radio to not work right.
· FCA Official
Hi there,
We're sorry to hear about the concerns you've been having with your Uconnect system recently. If you'd like us to look into this or offer additional support alongside your dealership visit, please feel free to let us know! We hope everything gets worked out quickly!
Thanks,
Courtney
Dodge Cares
1 - 4 of 4 Posts
