1 - 13 of 13 Posts
Parts: https://www.thegearbox.org/tr6060.html
Side note: replacing brake pads is easy! From this forum, two pins, one spring and one bolt, don't even have to remove the calipers!!!
Disclaimer: The following procedures should be performed at your own risk. I am not a certified TR6060 mechanic and only relied on common sense and a detail-oriented brain to perform this rebuild.
Background:
After 210 dragstrip passes and roughly 20k hard street miles, I finally had a catastrophic failure in my car as the 27 spline output shaft in my TR6060 let go, leaving me dead in the water and needing a tow. Up until this point I had done 100% of the wrenching on my car and frowned at the idea of having to rely on someone else to rebuild the transmission. After much deliberation, I chose to take on the project myself and ordered upgraded parts and a new 30 spline output shaft. I also ordered a set of carbon blocker rings and bronze shift fork pads to go along with my beefier mainshaft. The car only had 35k miles before the break and has 0 issues with the transmission. It shifted smoothly and perfectly so I did not expect to find any broken or otherwise damaged parts.
Tools: In addition to a regular mechanics toolset, you will need the following specialty tools:
  • Hydraulic press-I bought one from a local tool supply company
  • Snap-ring plier set-there are a few different snap ring sizes and styles that hold everything together so having a full set is a must
  • Bearing splitter(puller)-Also purchased at a local tool supply company
  • Punch set-the shift arm, shift fork, and some other misc pieces are held on with roll pins so you'll need a good punch set to hammer them out
  • T-40 torx
  • Gear puller with extended arms, depending on what is left of your output shaft
  • Portable band saw-came in very handy to trim down the broken output shaft and make a flat surface for the puller to pull against
  • Transmission jack
  • 5'(or larger) table to lay everything out and keep it organized
  • Rubber mallet
  • Feeler gauges
This guide assumes you have the knowledge and capability to put the car on jackstands, remove the rear cradle, the diff, and subsequently remove the transmission. SlickShoes has a great how-to thread located here which will guide you if you're unsure.
http://forums.corvetteforum.com/c6-t...ion-4-0-a.html
TEARDOWN
Important
Take note of the orientation and location of each piece you remove. Many of the parts are installed one way and cannot be reversed so you'll want to make sure you remove and set them aside in the exact order and orientation in which they came out.
Here is your starting point. The transmission is out of the car and ready to be torn down.
1) Start by removing the shift rod. This is done by rolling the rubber insulation forward and taping the roll pin out with a punch.
Plant Table Wood Automotive design Art
2) Remove the tailshaft housing. It will likely be glued to the main housing with silicone/gasket so a little tap with the rubber mallet should set it free. Once it is broken free, gently slide it off making sure not to scuff or scratch the bearings.
Here is the inside of the tailshaft housing. You can see the output shaft seal, reverse idler, and countershaft bearing.
Motor vehicle Bicycle part Automotive tire Rim Motorcycle accessories
3) With the tailshaft housing removed, you'll have access to 5th, 6th, and reverse gears and also the accompanying shift forks. In this picture, you can see what's left of the output shaft after a quick cut with the band saw.
Light Wood Gas Motor vehicle Machine
4) Remove the snapring and begin sliding the gears, spacers, and misc pieces off the shaft one by one. Most of the parts slide off but you will need to use the gear puller to remove the pressed on 5th, 6th, and reverse gears. The shift fork is held in place with a retainer/stop that is attached to the shift rail with a roll pin.
In this picture, you can see the output shaft bearing, gears, blocker assembly, 5/6 shift fork, and 5th gear.
Below that, you see reverse gear and another blocker/gear combination. Reverse gear is pressed on and will need to be removed with the puller.
Table Wood Artisan Tool Shorts
5) Continue removing the Reverse shift fork and gears on the countershaft and set them aside in the correct order. Once you've removed all the pieces from the rear, you should be left with 2 bare shafts and nothing attached to them.
6) Remove the reverse lock-out solenoid from the top of the transmission. Be careful not to lose the spring and roller guide assembly as it will fall out once you take it off. It is held on with 2 torx and 2 13mm bolts.
With the solenoid and cover removed, you can see the shift pattern and gear selector attached to the main shift rail.
Remove the detent from the outside of the case.
Use a punch to tap the roll pin down and out of the shift rail being careful not to lose it.
In this picture, you can see the location where the roller guide is positioned on the shift rail.
Discussion Starter · #2 ·
Automotive tire Motor vehicle Tire Gas Bumper
7) There are 2 torx bolts near the front of the transmission case that need to be removed. They are guide pins for the shift fork rails.
8) Now that you're done with the rear, you can shift your focus to the front half of the transmission.
Begin by removing the 15mm front cover bolts.
With the cover bolts removed, gently tap on the cover to break the bond free. If you have a Z51 or other model with a transmission cooler, be very careful not to break the filter as you slide the cover off.
The input shaft bearing rides inside the cover so you will need to reach in and support it while removing the cover. The other option is to place the transmission vertical and remove the cover with gravity on your side.
(my note: this is why women should give birth on a birthing stool. It adds around 8 pounds of free help to the baby making his debut.)
Automotive design Gas Engineering Automotive exterior Auto part
With the cover removed, you can see the input shaft, shift fork, and counter shaft.
Wood Tool Gear Machine Auto part
9) Remove the 5/6 and reverse shift fork rails. They are the lower of the 2 sets of rails in the above picture.
With the cover gone, the shafts have some wiggle room so you can move them around and slide the shift rail out. The 2 main shafts and 1/2 3/4 shift rails will be removed as one big unit in the next step.
10) CAREFULLY slide the output shaft, counter shaft, and shift fork rails out of the case as one big piece. Be careful not to ding up the inside of the case where the bearings seat.
Remember that the gear selector on the top of the case is free and will fall once the shift rail has been removed. Don't lose the roll pin!
Here is what you should see before removal. If you look closely, you can see the black plastic shift fork pads.
Camera accessory Automotive design Automotive tire Rim Gas
And here it is on the table, ready for the rest of the teardown. The counter shaft is one solid piece and can be set aside for now
Wood Gas Font Machine Flooring
This is what you should be left with, a bare case. Here you can see the 2 shift rail holes an also the locations where the bearings reside.
Automotive lighting Musical instrument Sculpture Art Idiophone
Gear selector/shift rail removed
Motor vehicle Wood Bumper Automotive exterior Gas
11) Set aside the input shaft and 3rd gear synchro/blocker assembly. You won't need these for awhile.
12) Starting at the front of the output shaft, remove the bearing with the bearing cutter tool and gear puller. Be very careful not to damage the cage for the rollers. Once the splitter has a good grip on the outer edge of the bearing, you can use the gear puller to gentle pull the bearing off the shaft.
With the bearing removed, you can slide off the gears and synchro assemblies and set them aside. Again--be very mindful of the exact order and orientation of their removal.
13) With the front-half of the output shaft removed, you're onto the final step in the disassembly. Remove the rear bearing with the bearing cutter/gear puller combo and then remove the rest of the gears, synchros and blocker assemblies.
Automotive tire Automotive design Suspension Motor vehicle Engineering
In my opinion, the rebuild process was easier and required less use of the special tools so if you've made it this far, you're almost done.
I'm a big proponent of "while you're in there" and chose to upgrade the blockers and bronze shift fork pads in addition to the much stronger 30 spline output shaft.
Hood Grille Bumper Wood Automotive design
Also, aside from the bearings, the gears that previously required the gear puller for removal can be baked in an oven at 400* for 20-30 minutes to expand the metal instead of using the press. Once they have baked, you can remove them and slide them in place with no resistance but you'll need to act quickly. You only have about a 30 second window from the time you pull the pieces out, until you put them in place before they cool off and subsequently return to their original size.
When reinstalling the new synchros and gears, make sure to use a small amount of transmission fluid to lubricate everything. I made sure I coated each side of all blocker assemblies, and each gear prior to installation.
14) You should now have a bare output shaft and a LOT of small pieces all organized on your table ready for installation. It should look something like this.
Tableware Eyewear Gas Auto part Kitchen appliance
Discussion Starter · #4 ·
15) Everything goes in the reverse of how it came out so we'll start with the pieces we just removed.
Hand Automotive tire Finger Camera lens Nail
Gear Coil Household hardware Differential Gas
Here is a picture of the stock blocker rings compared to the stronger carbon counterparts.
16) I replaced the 1/2 and 3/4 shift fork pads with stronger bronze pieces as they showed some obvious wear. The 5/6 and reverse, as noted before, were left as-is.
17) Reinstall the rear bearing.
18) Reinstall the front gears, synchros, and blocker assemblies and press on the front bearing.
If you purchased upgraded parts, now is the time to install them.
19) Now that you have the front half of the output shaft assembled, it's time for the most challenging part of the whole process. The output shaft, counter shaft, and shift forks all have to find their way back in the case at the same time.
There is not a lot of room and it can definitely be a pain but you'll want to take your time as the bearings need to find their home without scratching up or otherwise damaging anything.
I found it easier to build a platform out of a wheel and 2 race ramps so the long output shaft had somewhere to go. It will take a lot of tinkering and getting everything just right as the shift forks like to move around and not line up where they're supposed to be.
In this picture, you can see the detent that you would have removed in step 6.
Gear Automotive tire Bicycle part Rim Automotive wheel system
20) Now that you have the main pieces in place, you can reinstall the 5/6 and reverse shift fork. Once they're in place, reinstall the guide pins that you removed in step 7. If you look closely, you can see the bronze shift fork pads.
Automotive tire Gear Wheel Bicycle part Tire
Automotive tire Tread Motor vehicle Tire Automotive design
21) As you're sliding in the assembly, you'll also need to position the gear shift lever in place so the shift rail can slide through it before the 2 shafts bottom out in their bearing carriers.
Automotive tire Motor vehicle Automotive design Tread Bumper
Motor vehicle Automotive tire Bumper Gas Automotive design
22) I replaced the stock blocker for 3rd gear with the carbon version just before installing it. Once you have everything in place, you can get the front cover ready for reinstallation.
23) Clean off the old silicone on both the transmission case and the front cover. Use fresh silicone to seal the case. I used the black permatex silicone for its oil-resistant properties. Once it dries, it won't leak.
24) When you reinstall the front cover, be careful to line up the input shaft, shift rail, and the fluid pump(if equipped). Also be careful not to break the plastic filter for the fluid pump.
25) Once the front cover is on, you can focus your attention on the rear half of the output shaft. Reinstall the reverse lockout solenoid and cover. Again, make sure to clean both mating surfaces and apply fresh silicone to seal it.
26) Reinstall the synchro/blocker assembly on the counter shaft. Also reinstall the shift fork and retaining ring.
Window Wood Gas Engineering Auto part
27) After heating 5th gear in the oven for 30 minutes, reinstall it on the output shaft, making sure it sits snugly with the previously installed bearing.
Here you can see 5th gear on the output shaft, and also the blocker/synchro/shift fork assembly installed on the counter shaft.
Motor vehicle Planer Gear Automotive tire Bicycle part
28) Now is a good time to clean off the 2 magnets inside the case. Mine had a good amount of "fuzz" but nothing too alarming. My research told me that, like oil changes, it's normal to find some metal flakes and debris attached to the magnets. After all, that's what they're there for--to catch small metal pieces.
You can see the 2 round magnets attached to the bottom of the case.
Motor vehicle Automotive tire Automotive design Camera lens Reflex camera
29) Reinstall the gears, clips, synchro assemblies, etc, in the same order they were removed. Don't forget the oven trick.
30) Reinstall the reverse shift fork, reverse gear, and you're almost done.
I'm an IT guy and this kind of reminds me of the first time I had to completely disassemble a laptop, repair it, and put it back together again.
Hundreds of small screws and parts. You mess up and you have to take it apart again. lol
This is more difficult for my mind because so many of the parts look similar and you have to also get orientation correct.
I imagine that after you've done it a few times, it's not nearly so bad.
Even being a technical guy, I would never attempt this myself though.
Huge respect for you guys who can do this stuff!
Discussion Starter · #8 · (Edited)
With expensive Polaroids, one could document the entire process and get all orientations correct, while having a "card file" of pics to use on hand.
I could see myself doing this. 400 bucks versus 3500 or so parts and labor seems attractive, somehow. I may be inclined to go with more extreme super magnets in the case, and find a way to make them removable without taking the whole thing apart...
But, the bronze bushings, upgraded main shaft, and carbon synchros look good.
Discussion Starter · #12 ·
I found this note interesting, especially regarding the bronze bushings:
From an email to me from Calimer Transmissions:
Hello, The main shafts and gears are Cryo Treated. The same parts are then Polished in house to a very smooth finish that helps with wear and heat. The Vespal pads are shift pads made from a high Quilty plastic that holds up better than the bronze, which seems to break under stress.
1 - 13 of 13 Posts
