Not really. They can read that, but the on board diagnostics are not accurate. I had a 1.2 second 0-60 on my 2020 redeye!Is it possible to do a 0-60 in 2.6 seconds using the Black Key if you spin the tires enough?
Somehow my dealer managed to do this!
The manufacture uses P zeros because it's easier on the drivetrain.No he just broke it in for you lol. That’s what p zeros are for.. burnouts and dumpster fires that’s about it. With p zeros you barely press the gas and it does a wheel spin 0-60 in 2.6. I did the same thing a few times before I pulled those tires off. The p zeros are literally dangerous and they can’t take advantage of WOT.. they spin awefully down low and they also spin at the top of the rev range causing the car to hit the rev limiter
