I’m located in CA (Bay Area) my HCRE is scheduled to arrive from Jake in January ,
Is there a mileage number before the emission system will activate ?
The emissions system (systems) are active when they should be. For example even with the engine off the fuel vapor recovery system is operational.I’m located in CA (Bay Area) my HCRE is scheduled to arrive from Jake in January ,
Many years ago there were California certified cars and then 49 state certified cars, but now all US based cars are emissions certified for all states. Eventually the entire US automotive industry caved to us CA regulation loving wackos...I need to move.The emissions system (systems) are active when they should be. For example even with the engine off the fuel vapor recovery system is operational.
Then when you start the engine the various emissions systems like fuel/air metering, exhaust gas processing, and dealing with any vapor the gasoline vapor recovery system trapped all are active and remain active as long as the engine is running.
It might be necessary to drive the vehicle long enough to have all the readiness monitors tested and set to complete.
I never bought a car out of state when I lived in CA. I bought a number of new cars and one used car. The new cars were not required to be emission compliance tested for IIRC 6 years. The used car seller (a dealer) was required to confirm the car was emissions compliant before it could sell the car. In all cases I never had to worry about the readiness monitors being set to complete for any new car and the one used car only every other year, IIRC.
As long as the car is certified 50 state emission compliant or certified for sale in CA you should be ok.
Yeah I remember the days when CA cars came with a CARB sticker and one paid IIRC a $50 "fee" for the factory certifying the car complied with CA emissions.Many years ago there were California certified cars and then 49 state certified cars, but now all US based cars are emissions certified for all states. Eventually the entire US automotive industry caved to us CA regulation loving wackos...I need to move.
Correct, the tune must also be smog approved (stock) and any aftermarket tunes must be CARB exempt with an E.O. number. What a pain, especially when caught by a sobriety style check for aftermarket parts…welcome to Notizifornia!I have heard that now CA will fail u if you are running ANYTHING but the stock tune.
I flipped my ATS tune off for smog and failed because I hadn’t completed drive cycles. Had to put like 1-2 thousand miles on it before it was ready it was unreal. Just something to keep in mind if you plan on running a tune.
