1 - 5 of 5 Posts
About two weeks ago I noticed the car was taking almost a second to go into gear after dropping the shifter into drive. Within a few days the hesitation began taking a few seconds before engaging drive Then it started to feel a like a jolt when it engaged drive. I have not done anything to the car recently. It’s my daily driver. I took it to the dealer. The found two codes P1FB6-vehicle speed signal performance and P215C-output shaft speed - wheel speed correlation. The dealer tells me they believe the valve body needs to be replaced (which I think includes the TCM). They are waiting for approval to order the part(s). Has anyone had this issue and if so, how was it resolved. Thanks.
In The Market
The A8 has a complicated procedure for trans fluid change. Brief hesitation before dropping into gear is a normal German thing. Not several seconds. Just long enough to throttle it before it’s securely in.
Discussion Starter #3
I’ve had it for over a year. Normally you can’t even feel drive engage. It’s only in the last two weeks that it started to hesitate before going into gear. I can’t find much info on those two codes.
If it’s cold outside 40ish with a cold start and putting the shifter right into gear there will be a delay, if it’s doing it hot that’s a cause for concern
1 - 5 of 5 Posts
