You need to gather more info about what's going on with the car. At minimum, what's the air intake temp throughout the run and especially going into the straightaways, and like someone said, log it, if possible.
My 16 HC starts to fall off when IAT hits about 115. Depending on IAT it runs between 6.80 and 7.05 in the 1/8 at 4500 DA.
The power chiller is basically worthless on a big track, isn't it? Once you use up the chilled coolant, which takes less than 15 seconds probably, I don't think it would be able to keep up with removing more heat in a race environment on a big track where you are pushing the car as hard as it will go. The chiller, from my understanding, and reading about it, and looking at posts on here, etc., is best for drag racing. But maybe someone who has tried to use the chiller on a big track can comment on whether it works well or not.
Doesn't seem like many people use superchargers on big tracks. That's probably because of the heat issue, not to mention it's more weight, too. But I am not a big track guy, so maybe someone can comment on that who goes to these types of events a lot.
Lastly, there will always be a faster car than whatever you're driving. Max out what you have. Focus on improving your times with what you have. My two cents anyways.
And most importantly have fun.
