1 - 15 of 15 Posts
Well, I had no luck locating 315/50/17 and could not find any information whether or not these gigantic 315/55/17 tires fit.
I am surprised to report they do fit. We ran errands this afternoon hitting dips in the road and loaded groceries without any rubbing. The car is stock ride height with stock length sway bar end links.
Tire Wheel Car Vehicle Land vehicle
Tire Wheel Vehicle Automotive tire Car
Font Material property Rectangle Electric blue Signage
‘16 A8 Shaker
How tall are your fronts?
Do you have to fully disable esc at all times running that much stagger? Seems the puter would be freaking out and applying front brake
Discussion Starter · #7 ·
The rear tire is a little taller than I wanted. So far, the computer and ABS system is not freaking out yet. That may change once I eventually get matching fronts with skinny tires as I am on the stock front radials.
I like the way it looks and also like having the extra sidewall to help absorb the driveline shock.
Reactions: dragrcr
View attachment 598211 View attachment 598212 View attachment 598213
What PSI are you running in your tires.? Have you lowered the PSI to race and still good up top.?
Discussion Starter · #10 ·
They are at 28psi. Sadly I have not been to drag strip yet. I put them on car and we drive to dinner and I took them right back off. They appear to have plenty of room.
Reactions: DaytonaKid
SRT DEMON ONESEAT
What wheels are these
Weld RTS
· Forum Discount Code: HELLCATORG
RAM TRX / Jeep 392
2021 Super Stock (on order)
Good info... Sent you a PM to see if there are any follow up results etc.
Thanks!
1 - 15 of 15 Posts
