1 - 14 of 14 Posts
Challenger SRT Demon
Hello!
I see that by holding the T/C button I can remove the traction but I need to completely remove the ESP.
Has anyone had any success in this? Unfortunately, its not like the hellcat where the T/C button would remove both.
Unlike the hellcat, which completely turned off ESP, you cannot drift as soon as the car gets a little sideways the computer cuts in. Big No no,
For the ones throwing caution to the wind, I am experienced and driving on track.
Thanks!
BMF
Reach out to McJaxOn.
He is the subject matter expert on the Dodge Demon
Reactions: dragrcr
Several of the features do not work as they should on 2018+ cars but I have tested line lock and things like that.
Most of what doesn't is directly related to the fact they switched uConnect in 2017. The Panasonic ones handle everything differently.
Nav in motion doesn't work. Any auxiliary video control doesn't work, etc.
Discussion Starter #11
Hi I emailed the company they do not have a tazer product for the demon.
Hello!
Unlike the hellcat, which completely turned off ESP, you cannot drift as soon as the car gets a little sideways the computer cuts in. Big No no, View attachment 528341
Thanks!
I am pretty sure you are doing something wrong. So you say you are disabling by holding the button for 7 or 10 seconds? Then a chime sounds and you get the warning in the dash that the stability control is fully disabled and you then you still cannot do a donut? Do you actually have 2 separate warning lights with the car and the squiggly lines? What exactly are you doing? Tell me exactly what your procedure is from start to fail?
I am skeptical because there are many videos on youtube showing Demons doing donuts. And I doubt those Guys know some secret that I do not know. The Demon has Traction Control and Stability Control and as far as I know they can both be disabled just like a Hellcat.
Nerdboy305
Straight from the Demon Supplemental Owners Manual ; "Full Off This mode is intended for off-highway or off-road use only and should not be used on any public roadways. In this mode, TCS and ESC features are turned OFF. To enter the “Full Off” mode, push and hold the “ESC Off” switch for five seconds while the vehicle is stopped with the engine running. After five seconds, a chime will sound, the “ESC Off Indicator Light” will illuminate, and the “ESC OFF” message will display in the instrument cluster. To turn ESC ON again, momentarily push the “ESC Off” switch. "
1 - 14 of 14 Posts
