Thank you for that info. I want to go for this instead of ravelco.It's available but dealerships (at least where I am) can't download it because of some kind of Stellantis server issue
Yesterday (6th) the dealer had no problem with my Cat and didn't say there was any server issues..It's available but dealerships (at least where I am) can't download it because of some kind of Stellantis server issue
Here's the official TSB.Anyone know the TSB # or something I can share with my Dealer?
Tech told me if he locks out the HUB - none of my keys will work and still would need some kind PIN# that only a regional manager has...???
Thank you for sharing that. Would be easier to explain to dealers. Currently most of them say, we don't knwo about itHere's the official TSB.
Your tech is wrong. Your current keys will work. Additional ones cannot be programmed unless a new RF-Hub module is installed.
Doesn't Ravelco have a perfect record though?You should. People put too much faith in the Ravelco.
No security system is 100% secure.Doesn't Ravelco have a perfect record though?
I have found that it is best to print out two copies of everything you can find on whatever issue you want done and leave a copy on the front seat so the techs can see it. They still probably won't read it though, I had two techs spend two hours on a DRL issue on my car and even after telling them and writing on the tech instruction sheet that the parking brake must be off to test this in big letters with a Sharpie, they worked the whole time on it with the brake on and finally gave up. Unbelievable some of these tech I tell you.Thank you for sharing that. Would be easier to explain to dealers. Currently most of them say, we don't knwo about it![]()
Has anyone been charged for this? Service department is trying to get the 0.2 hours of labor outa me. not much- just wondering.Here's the official TSB.
The Ravelco is a phenomenal system. It’s not visibly easy to track the wires that are coded and not coded. You don’t need to modify the wiring harness. It is a visual kill switch that is works. A pouch is a joke as soon as you push a button out of the pouch. The RF hub update isn’t available for all year models yet and is so slow to roll out that people are getting their cars jacked waiting on Dodge.You should. People put too much faith in the Ravelco. With the Ravelco you have to modify your car's wire harness. The SiriusXM Guardian Convenience + Security package, RF-Hub lockout update, and faraday pouches for your fobs is all you need. I recommend the Disklabs KS1 faraday pouch. It's very durable and used by law enforcement. I have two. One pouch can fit two fobs.
I just had it done. They tried charging me but I showed them the TSB where it says it's covered under warranty and they didn't give me any trouble.Has anyone been charged for this? Service department is trying to get the 0.2 hours of labor outa me. not much- just wondering.
Thanks.
2022 models equipped with the deluxe alarm system have a tilt and interior proximity sensor built-in. Unfortunately the Uconnect app is currently a pos. It works but just barely. Sending remote commands takes forever and GPS is slow to update. I had a Viper remote start/security system installed and it works a lot better than the factory version. The Viper app has more features too. It shows cabin temp, lock status, hood, doors, trunk open/closed status, can pop the trunk with it. Viper remote commands and GPS updates are lightning quick. When you remote start the car using Viper it shows you a timer that tells you when the car will auto shutdown. The Uconnect app pales in comparison. It's actually pretty embarrassing how basic and slow the Uconnect app is.The Ravelco is a phenomenal system. It’s not visibly easy to track the wires that are coded and not coded. You don’t need to modify the wiring harness. It is a visual kill switch that is works. A pouch is a joke as soon as you push a button out of the pouch. The RF hub update isn’t available for all year models yet and is so slow to roll out that people are getting their cars jacked waiting on Dodge.
The Ravelco shouldn’t be the only system someone has, GPS tracker hidden in the car(not the dodge one that can be disabled in seconds), ultrasonic sensors, and tilt sensors should be added too.
This is pretty funny right here.
If your kill switch is “on”, how do you start your car remotely?A kill switch and GPS subscription for (5) years would be less than that and far more effective and u still get to start ur car remotely!
I was wondering the same...although I'm an electronics dummy, so....If your kill switch is “on”, how do you start your car remotely?
And if you can, then a thief can as well correct?
