Hey. That's great idea, wish I thought of that.Do a search. Thanks.
OK, So it doesn't require a longer belt?With 2.85/2.75/2.65 supercharger pulley, and ATI overdrive balancer: K100594HD
With the Ripatuned Idler you will most likely gain extra belt wrap. You adjust how you want it
Perfect. Thank youI am assuming your tensioner is has extra from factory location. You want to keep your tensioner at about the factory location so if your belt is just a little long right now and you have room on your tensioner you can use it it’s up most position without getting a longer belt. After looking at your tensioner, figure about an extra 1/4 inch belt length needed after installing the Ripatuned to keep the tensioner at the same location. If you do not have the extra play, order a slighly longer belt.
