Can anyone recommend a make and model of digital tire pressure gauge? As nit-picky as Hellcat owners can be I'm sure someone knows of a good one.
Amazon.com: AstroAI ATG250 Digital Tire Inflator with Pressure Gauge, 250 PSI Air Chuck and Compressor Accessories Heavy Duty with Rubber Hose and Quick Connect Coupler for 0.1 Display Resolution : AutomotiveCan anyone recommend a make and model of digital tire pressure gauge? As nit-picky as Hellcat owners can be I'm sure someone knows of a good one.
This is what I've found as well!10 different gauges 10 different readings, when u find an accurate one, post up
SAME one I got, and it matches the car's sensor readings so that all that matters to me.It is not digital, but the Jaco ElitePro Tire Pressure Gauge - 60 psi is pretty damn accurate and easy to read with the locking dial display. I think I paid a little over $20 off Amazon.
Wasn't necessarily in the market for a tire gauge but just ordered one of these! LOLIt is not digital, but the Jaco ElitePro Tire Pressure Gauge - 60 psi is pretty damn accurate and easy to read with the locking dial display. I think I paid a little over $20 off Amazon.
I do too but the active one is more accurate than the one that holds. I don’t have video can’t prove itI trust any digital gauge that Longacre produces. Also, if you're looking for a digital gauge that will last you "forever" you may want to look at the intercomp products. They're a bit pricey. I've had one of them for a looong time and it still works as well as it did when new.
Also, there's a saying in drag racing "never borrow your buddies tire pressure gauge". The variance between gauges is almost ridiculous.
Nice!!I've finally made a decision. I've purchased a:
"Milton S-568 Heavy-Duty Digital Tire Pressure Gauge and Inflator with Air Chuck"
Not cheap, but made in USA and "meets ANSI/ASME B40.1 standard".
$75 bucks & free delivery.
Yes, yes, I agree - I'm over thinking the entire issue.
DAMN! Amazon says this does NOT fit my 2015..............I use this.............
Longacre® 52-53006 Econo Digital Tire Gauge w/Active Display
Longacre 52-53006 Econo Digital Tire Gauge w/Active Display
Buy Longacre 52-53006 Econo Digital Tire Gauge w/Active Display at Amazon. Customer reviews and photos may be available to help you make the right purchase decision!www.amazon.com
