Why do you want to no that???What pads have you been using with them?
know*Why do you want to no that???
????know*
Oem padsDifferent pads will impact the wear on the rotor. 1600 miles with an aggressive brake set up is not the same as 1600 miles with a more mild set up.
Thank you kindly.Different pads will impact the wear on the rotor. 1600 miles with an aggressive brake set up is not the same as 1600 miles with a more mild set up.
Are you interested in them I can give you a better dealThank you kindly.
