About almost a year a go I swapped out the OEM sway bar end links for shorter aftermarket ones from UPR to accommodate fitting my 17x10 track wheels.
However lately they have been making loud croaking noises when driving around especially at slow speeds and uneven ground. The noise is so bad it's ridiculous. I've had the shop lubricate them and the noises have pretty much stopped for a while until as of recently they came back.
Since I ordered these shortened sway bar endlinks a while ago through the shop, I didn't know if they came with grease fittings or not.
I've thought about switching out these UPR end links for either the ones from Bwoody or HHP. I believe Bwoody's end links have grease fittings but not sure if HHP's end links do. I've been looking at these in this link to possibly switch too.
Do you folks recommend I switch my UPR sway bar end links for different ones? If so, which ones have you been happy with (noise free) and prefer? Thank you
