I agree 100% that about your reputation comment but reputation's can also be repaired. I can prove this by using John Hennessey as my example. He BURNED the Corvette and Viper crowd to the ground and now has come back to build some high dollar modded cars that perform well and seems to have a thriving business.
My best suggestion pretty much parrot's what you (Blkout) said and treat people right the first time around because Folk's are trusting you with (what I consider) a large amount of money and just because you made one fast car, doesn't mean that you can consistently do it again. You have to prove that and the first couple of builds are paramount for you to get your rep established.
In all Honesty, I wouldn't automatically trust you because you've got many followers on Youtube. They mean nothing to me because I don't know them and I don't know you! Trust needs to be earned over time and results. You treat people right and they usually respond in kind!
Sorry to be a buzzkill too but I'm skeptical by nature and it's just how I think!
PEACE!
In actuality, turbo's are the restriction. They just eliminate parasitic drag over a blower. A turbo will slow down the exhaust speed until it comes out of the compressor side of the turbo, then it's not a restriction anymore. It's kind of like the old Hotwheel's Supercharger that you put on the track when playing with your Hotwheel's cars. The car is slowing down as it comes between the wheels and then the spinning wheels of the supercharger grab the sides of the car and "Boost" it out of the other side.
The exhaust is the car coming in and the "Boost" is it coming out.
The downside to downforce is that it creates drag to and can slow a car down. Everything has a compromise and things depend on what you're trying to accomplish. If it were a road course, then downforce is beneficial. On a drag strip, not so much because it's more about weight transfer than aerodynamics. Granted, a slipperier COD (Coefficient of Drag) will help on top, but that's not downforce.
No belts and/or crank pulley hanging off of the front of an engine. Crank snout isn't subjected to a belted pulley trying to spin off of the front of it. For some reason, turbo's seem to be easier on engine parts just because of how the boost is delivered. It's less violent but more efficient. If that makes any sense (it does in my little peanut head but sometimes I lose things in translation
I agree with number 1 but disagree with number 2. A PD (Positive Displacement) or TS (Twin Screw) blower isn't linear in power and will usually beat a PROPERLY sized turbo in the bottom end power department. You can undersize a turbo to pick up on the bottom but you'll overboost on top unless you have a sequential boost setup (which is unlikely because of the complexity of the system).
Centrifugal blowers are linear in power delivery because of how they work. They are basically belt driven turbochargers, which is why the Really quick drag racers use them. The belt allows them to build boost pressure quicker and not rely on exhaust gases to spin them (to build boost). The downside is parasitic loss and the pressure on the crank snout.
Once again, compromises.
I agree with you about it being about efficiency but it might also be that you need to make more power with the blower because of how much it's using up to spin it.
As Cheapokitty said, Boost is a measurement of restriction and it's ALWAYS more beneficial to make the same power on the least amount of boost possible. That's a sign of the efficiency that you are talking about. Not too mention, it's quite a bit easier on parts too.
Once again Cheapokitty, I Apologize for the hi-jack and will do my best not to let it happen again!
