1 - 19 of 19 Posts
2019 challenger redeye
Last night I filled up with reg. gas not 93. Is there a trick to siphoning gas out of a REHC. I can't get a 3/8" hose down to the gas something in the way. I was planing on going to the track Friday night.
Depress the lock tab (@ the 3 or 9 position) on the tiny door blocking access to the tank. You can also use the filler neck from the trunk to depress the lock on the door. The Owner's Manual has info on this along with the sticker on the underneath side of the spare wheel well cover.
I sorry, where is the lock tab?
SRT DEMON ONESEAT
Drivers side fuel rail. Pull Engine cover, screw this on and it pumps nicely into a container. Run it until the engine stalls then turn off the ign. Car will start with this in place. Fuel comes out full stream but little pressure. So, full tank will probably take 1/2 hr.
Azure Eyewear Electric blue Gas Wire
1 - 19 of 19 Posts
