1 - 11 of 11 Posts
I have been noticing a very slight coolant smell from the front of the car when it’s hot after I park in the garage. No leaks anywhere on the garage floor and I couldn’t see any signs in the engine bay. The reservoirs look like they are at their correct levels and the car doesn’t run hot at all.
I did a search and there are a ton of posts on this but no real answers.
Anyone else have this or know of a possible answer?
Car is a 16 with 4K miles
If it has that few miles, maybe some spilled coolant, but a leakdown test would help you find if there is a slow leak somewhere, but you have to be careful not to OVER pressurize your cooling systems: A) the engine coolant and B) the supercharger coolant.
If you are truly fanatical, if the leakdown test proves that pressure is being lost from one of the systems, you can make some very soap-dense liquid and mist it all over the engine so the entire engine is coated with soapy film, and then watch for growing bubbles, while pressurizing the system and applying soap, but it works best if you empty all the coolant first, so only air gets out, which escapes more easily than water.
There are a few places that are likely to leak, but quite a few that are physically capable of leaking.
If this was a billion-dollar question, then you could submerge the entire engine/front end in water and then pressurize the system with air and watch for bubbles.
I replaced my coolant systems both with loose caps for no pressure and kept filling them up with food-grade propylene glycol as the factory water-PG mix boiled off all the water over time. I am not so worried about coolant leaks. I can fix them now with tape or silicone if need be, as I have done before.
The odor of antifreeze when the engine/cooling system is hot is almost certainly because of a leak.
Had one car that on a hot day I smelled anti-freeze. Got car into dealer service and tech put car on lift and very clearly at the water pump there was coolant leak sign, and sign it had been leaking there for some time. I'm pretty good about looking for any signs of a leak under my cars when I walk up to them and I never saw any leak sign on the ground under the car.
Yet, this same car "fooled" me when after I had the radiators replaced upon using the car -- essentially giving it a shake down test drive before heading out on a 2K mile drive back home -- I smelled anti-freeze. Took the car back to the dealer service department. Tech checked over the car and reported no leaks. He did admit he spilled some coolant when refilling the system. He rinsed the engine thoroughly and started the engine and got it to temperature and there was no smell. I took the car and after some more shake down testing deemed the car ok and drove it home with no problems.
My advice is do a hot pressure test.
With the engine dead cold top up the coolant level using distilled water. Do not over fill the cooling system but bring the level up closer to the max line. The less air space in the system the better.
Be sure the cap is on properly.
Turn off the A/C.
Drive car around town -- my experience this gets the engine -- coolant and oil -- hotter quicker and just hotter than a drive at freeway speeds -- until the radiator fan comes on due to the coolant temperature reaching the fan on trigger temperature. With my Hellcat this appeared to be 216F.
Go home.
On your driveway raise RPMs to ~1K and hold until the radiator fan comes on. When it does shut off engine.
Raise hood.
Wait.
The heat load of the engine will raise coolant temperature and pressure and if there is a leak almost certainly you'll know it.
Most likely the leak will be from the water pump seals, but I had one car with a coolant tank that had developed a crack along the bottom of the plastic tank at the mold seam.
Another time the coolant tank cap proved to be defective. It allowed pressure to escape at too low a pressure. With this leak I did not smell anti-freeze because only water vapor escaped. But I did spot some drops of water on the trunk lid above the coolant cap. I tented the cap with aluminum foil and after a few minutes after I shut off the hot engine water had condensed under the foil. A new cap put a stop to that.
Check above the headers and see if you can see anything leaking from the heads. A head gasket or cracked head may start small but can turn into a major problem if not found and corrected quickly.
Check your oil too and see if it is a milky color. If so stop driving it immediately.
· FCA Official
Hi BigBuckeye,
We apologize for the trouble you are experiencing. If you are not able to remedy this concern with the advice provided here, we kindly recommend connecting with your local Dodge dealer. If you are in need of any assistance with that process, our team is available via private message.
Rob
Dodge Cares
my 2015 had the same coolant smell. Id always get a whiff of it in traffic and at home when I shut it down and got out. Dealer never could find it so, on one of my routine oil changes I explained it to the actual tech working on the car, not just the service writer he let the car run and put it on a lift and searched for half an hour. Finally found a weeping leak in the lower corner of the radiator. It was subtle enough to not leave any trace but enough to cause the smell. Radiator was replaced under warranty.
Reactions: BigBuckeye
Thank you- I’m not sure if I’m imagining it or not….I’ll have the dealer check it out on the next service
Unless the next service is scheduled for the day after you posted you shouldn't wait to get this looked into.
A cooling system that is suspected of leaking puts the engine at some risk of localized overheating. The pressure the system develops prevents the hot coolant from boiling. If the pressure is not maintained the coolant can flash to steam in the hottest parts of the engine -- the heads around the exhaust port/valve -- and the steam "bubble" blocks coolant from contacting the hot surface and removing heat. Localized overheating is the result. This can result in gasket failure or even a cracked head.
Bottom line it is not wise to continue to drive the car with a cooling system that might have a leak.
2015 Charger SRT Hellcat
I popped my hood after a week or so yesterday. I also had a faint coolant smell, but have no leaks. We also have overflow tubes that go to the tanks, so there will be always something.
I ran mine with no rad cap or supercharger tank cap for days. I just boiled off my water and left it with pure propylene glycol. I didn't really go after it during those days, however, with the exact thought of localized overheating in mind. I added a few gallons of propylene glycol, which does not boil off without pressure.
The best way to limp a car anywhere with a known leak is to drain it, cleanse leaking area with brake cleaner spray, then fill leak with silicone or use electrical tape on it if it is a hose, then fill the system with propylene glycol or propylene glycol/water mix (pink) and use no cap on the cooling system. If using mix, be gentle with it until you have boiled off all the water, then go back to life as usual.
I've repaired my radiator with silicone blue, and used electrical tape on my rad hose (old dodge truck) with propylene glycol coolant, never leaked.
Of course, a more sure-fire way of not having coolant leaks is just use zero pressure and propylene glycol from the get-go.
1 - 11 of 11 Posts
