The whole smog ecu tune thing around here in So Cal is changing my mind. The Redeye and Hellcat use the same kit. Here’s an email from LMI that I received after asking them what kit fits.What changed your mind about using it ? Do you have the part number as I have a Redeye
Bump for a good buyer. Regarding the smog, at least it’s 8 years before you’ll need to revert back to stock for smog purposes. Unfortunately, unless the intake and tune are CARB approved, the car will fail both the visual and ECU test...all while passing the sniff test. 😐The whole smog ecu tune thing around here in So Cal is changing my mind. The Redeye and Hellcat use the same kit. Here’s an email from LMI that I received after asking them what kit fits. View attachment 577996
