1 - 20 of 47 Posts
I'm looking to increase my supercharger whine, and in my search the bwoody intake always comes up. However, there doesn't seem to be a consensus on if it actually reduces overall hp/performance (due to heated engine air being sucked in), or if it improves it.
I just want to increase the whine sound, but not at the expense of power, even if slightly. Has anyone done any before/after dynos of this intake?
· DRIVESRT.COM
So far, some dynos have shown gains (Bwoody IAT harness HP gains!!! Dyno results) and some 1/4mi track results showed gains of 0.1-0.2s and an increase of 1-2 mph trap speeds that have been debated.
With no filter and the stock box, about 0.1s gain in the 1/4mi (No stock filter and OEM airbox)
No reports of losing HP with them.
If the intake temperature on the BWoody exceeded the stock air box temperature (most likely to occur at idle), you would see some loss in initial performance.
In two measured scenarios on previous Challengers, an open filter element took roughly 1 minute to reach a certain temperature whereas the stock box took 3 minutes. Conversely, once moving, it took 1 minute to reach 5 degrees above ambient temperatures with an open element vs. stock box it took 2-3 minutes to reach 5-10 degrees above ambient. Not saying this is the case for the Hellcat since the design of the stock airbox also includes the front air catch inlet. However, you'd likely see similar results where an open filter will react quicker than the stock box to intake air temperatures changes.
Overall, an open filter element will react quicker to temperature fluctuations than a closed filter air box (you'll notice this in throttle response). Just don't sit idle too long and keep it away from rain and you'll be alright.
Challenger SRT Demon
I consistently lost just over 1 mph off my trap speed with the BWOODY... sold it and went back to stock... car picked right back up
Yep I believe it these cars are too well engineered anymore to mess with you can't even change oil without getting in trouble put the wrong oil in that car like a heavier weight and you stand a chance of wrecking the engine because of the tight clearances involved .
Discussion Starter · #6 ·
Yup, everything is well engineered on this car. You basically have to do nothing other than tires. Unlike the SRT-4, where everything was limited in some way and you had to upgrade almost everything, including the intercooler to get more power. Hellcat has pretty much all the highest performance components right from the factory.
John
We need to talk!! You know I run the B-woody.. Are you being serious? I like the looks of it more that the sound of it. I just finish up my stock airbox at the shop with the Hellcat logo. Just have to clear it. Ho man!!
John
Yes sir!! with the combo I had at the time, I would consistently trap high 137, low 138... with the BWoody, in comparable DA, I only saw 137 once..otherwise, high 136 was the norm.
Sounded cool, though!!
So it's time to finish up the stock air box I guess? I really did not know that. For some reason I was under the impression you were trapping the same MPH. Thanks for the info.
I could not tell if I lost power or not. Youre going to go from 707 to 700? For me it was worth it for the sound. It sounds so bad ass. I will literally go for a drive around the block just to listen to it
Discussion Starter · #11 ·
I think I'll get this intake in combination with a 3.09 gear and a tune, that way any performance "loss" would be offset by the gains.
FWIW I talked to Chris @ Legmaker intakes and his Carbon Fiber intak will be out in about 3 weeks .... towards then end of October CF for the win .... I have had a few street bikes over the years and let me tell you ... you could ride for hours and get off the bike and instantly touch the exhaust and not get burned .... it would be very warm but not enough to burn you .... Bwoddy is metal and have only heard good things about them but metal heat soaks ..... just sayin
How much less money is it going to be?
· Super Moderator
Top Cat was asking Chris last year to develop an CAI for our cars.:)
The great thing is, Chris will actually have the test results for us and then they will go on sale. I spoke to him a couple of weeks ago too and so far they are getting good results.
I'm looking forward to testing one out on my car or maybe even on my husband's Top Cat's car.
Linda :)
· Texas President
The great thing is Chris will actually have his intake tested. I spoke to him a couple of weeks ago too and so far they are getting good results.
Linda :)
Subscribed
The Legmaker intake would be an intake that I'd strongly consider purchasing.
I would really like to see this when it comes out.
· 10/30/15 DELIVERED ON DEVILS NIGHT
The B Woody is an aluminum tube that will get hotter then the stock one which is made of a plastic, the colder the air the better performance. But the added whine sounds sweet.
1 - 20 of 47 Posts
