Didn't think they still used a 17" spare. All the later Challenger and Charger use 18" spares far as I know. The 18" will fit the rear on Brembo cars. The 17" I don't know but would guess not.
Thank you Slidd, that was my concern as well.
No, absolutely not, for use on rear only. If you got a front flat, you would need to do a double swap.Do not think that would clear the front Brembos
And there you go. Your spare tire worries are now over. I bought ferrada wheels for mine but I have kept the original hellcat wheels so that when I go long distance I just throw one of them in the trunk good to go.I have a factory slingshot brass monkey wheel with tire if interested. 20x9.5 OEM in excellent condition.
Who’s releasing this spare tire? And where can I buy one?So totally off topic, but since they are releasing a spare tire specifically for the 2021's with the bigger brakes, I wonder if the wheels alone could be used as front runners in conjunction with a pair of race skinnies as a stop gap to there not being any specific drag skinnies for the 2021 cars with 6 pot brakes.
The M&H front drag tires are 28x4.5-18's (165/85-18) and have a recommended wheel with of 4"
The spare wheel is 4" in width. The limiting factor is that it looks like you need to run the supplied spacer to install the wheels on the front.
The wheel and tire is under $350 and an M&H drag skinny is is about $260 a pop, so for about $1200 and change there might be a viable front wheel setup.
Modern Spare says some time in 2022 they will release a 6-piston 19" spare.Who’s releasing this spare tire? And where can I buy one?
But do I need it, Slidd? Or will the original 18” spare fit over the WB brakes? I can always do a dual swap if I have to right? I just asked about this on a super old thread over on the other forums too.Modern Spare says some time in 2022 they will release a 6-piston 19" spare.
You would have to do a double swap, the factory 18" spare will fit on rear only.But do I need it, Slidd? Or will the original 18” spare fit over the WB brakes? I can always do a dual swap if I have to right? I just asked about this on a super old thread over on the other forums too.
I haven't seen them post a tire size so it's still possible it will still fit, assume the 19-inch wheel is for caliper clearance only and the overall diameter might still be the same.And how the hell is a 19 inch wheel going to fit in the trunk? I remember the 18 being a tight sweet when I installed it in my SP.
