1 - 11 of 11 Posts
My 2020 Redeye Wide Body came with two sets of rims/wheels, which are the 305/35R-20 Pirellis. I have three questions:
  1. Can I throw one of the mounted wheels in my trunk and use as a spare in case I get a flat?
  2. I also own a 2019 Hellcat classic body that has P275/40R20 on them. Can I use one of the 305/35R-20s on it as a spare in case of a flat?
  3. Is it safe to assume that if the answer to either one of the questions above is a "yes" that I should be carrying around the fronts as spares instead of the rears since I am under the impression that the rears are wider than the fronts?
Thank you!
Discussion Starter · #2 ·
LOL. Did someone recently get sober? Perhaps I didn't phrase the question correctly. I was asking if it was ok to run them on the car (if they would fit on both cars); not if they would fit in the trunk. Call your sponsor dude LMFAO.
You can run the 275 as a spare for the Widebody as both are about the same diameter, the early Widebodies actually left Brampton for the Upfitter riding on 275's.
But no, you cannot run the 305 as a spare on the NB as the offset is all wrong and it won't even work in the rear. So you'll need another 275 on the factory 18.5 mm offset wheel or similar.
'22 Sinamon Redeye Standard Body
Thank you!
Lmfao this is so entertaining! Seriously, here is an alternative for you. I had one... great quality.
Discussion Starter · #9 ·
So would this spare fit ALL 2008-2020 Challengers??? As in both the narrow body Hellcat and the Redeye Widebody? Perhaps that is what the spacer is for? Will this kit fit in the trunk 😂
The spacer is for the front, (big brakes). And from what I've read about it, it should fit in trunk. It will fit both regular and wide bodies.
I thought Modern Spare said they were coming out with a new spare that did not require the spacer even on the 6-piston brakes but this one still has it. Spacers are a pain, I'd almost run the spare on the rear only and it's close enough in size to not hurt the limited slip.
1 - 11 of 11 Posts
