How do you remove the SRT emblem in the grill on the Challenger? Thanks.
How hard is it to take off the front bumper without damage?If you don't want to risk damaging your grille, you need to pull the bumper off and remove the press on washers, off the plastic studs on the emblem, from the back.
Really now, just said I pulled it off. ZERO damage AND can put it back on any time I choose.If you don't want to risk damaging your grille, you need to pull the bumper off and remove the press on washers, off the plastic studs on the emblem, from the back.
On these cars, it's relatively easy actuallyHow hard is it to take off the front bumper without damage?
Yes I know you "CAN" pull it off, but the correct way is to pull the bumper off and get at it from behind though.Really now, just said I pulled it off. ZERO damage AND can put it back on any time I choose.
had my SRT8 on and off many times, made to come off and on. The 19 has a SECURITY clip on it, the plastic will let you pull it thru. then CUT the stupid square off and nobody know any diff.
The Expert
