1 - 20 of 20 Posts
Hey guys,
I just grabbed a 2018 Challenger HC Widebody. I has a leg maker CA intake, dual catch can, and Borla S type exhaust so far. I was offered a military discount to put a 2.85 metco upper pulley, 10% over on the lower, D1300 injectors, belt, intercooler, splitter, pinned crank and ATI balancer. Finis her off with a HPP tune (all for 4k). I use my HC as a daily driver and they think she can pull 840 on the dyno at 93 oct. Is this a good deal? And can the stock blower handle that upgrade?
I wouldn't do it if it's a daily driver, personally. Your current mods won't void the powertrain warranty. You do pretty much everything else you listed and you no longer have a powertrain warranty.
Can you afford to be out $20k if the engine grenades? If so, go for it. If not, you need to be seriously questioning why you're doing what you're doing. A 700HP daily driver with a factory warranty is pretty sweet. That's part of why it's such an expensive car to begin with.
Lower pulley and call it a day.
No need for injectors or additional upgrades.
I disagree, those mods make a unbelievable "93 octane tuned" daily driver. Better add drag radials to that list.
1300 injectors are not needed, 1050s will do.
If your worried about warranty, then don't mod it.
Discussion Starter #5
Thanks for the feedback. I'm not worried about the warranty, just dont want to grenade the blower. The tuner and the mech seem to think the stock HC blowers are good up to 1000 rwhp before rods and bearings upgrades but I can't seem to find find any HC owners who says that setup will be okay for a daily.
Your blower will make noise when the bearings are going bad. I would buy boca bearings for the snout and bearing plate, but wait till they are bad to put them in.... or wait till it is convenient to do so.
Discussion Starter #8
Do you happen to have an part no for these? I'm chatting with boca and they are asking.
How about hybrid ceramics? You can't use full ceramic due to outrahgeous RPM, but hybrids offer less resistance and longer life. The real ones are pricey, though.
Discussion Starter #10
It looks like boca has some hybrid but I don't know which is the correct set yet. They range from $48 to $248 depending. 6203 is the standard HC but I dont know how to differentiate between the 6203 RS v. The 6203C LL v. The 6203 LL/H. So I'm waiting to find out more info and will push when I find the right ones.
Here you go
No problem.
I have the metco 2.85
Did you decide against the hellraiser or what the metco the only one brought to your attention? The hellraiser is supposed to be decoupled like the stock pulley (actually even made by the same people who made the stock pulley). It's more expensive though by a good amount.
I chose a preowned metco and hub for $120 from the marketplace, looked brand new. 700 on the hellraiser is rediculous. Not to mention I dont see the benefit on the automatic, I dont chop my throttle at redline and decelerate on motor drag.
Discussion Starter #18
I wasn't aware of it when I purchased. Metco came highly recommended and so I bit. I haven't put it on yet. I'm still deciding if the mods are worth the $$. I'm leaning towards doing it.
Correct
1 - 20 of 20 Posts
