So just get in the car, press the gas and hit the start button? Or gas and brake? Then it stops by itself after 10 seconds?Press and hold the pedal, the cranking will stop after 8-10 seconds
thanks
Gas and brake👍So just get in the car, press the gas and hit the start button? Or gas and brake? Then it stops by itself after 10 seconds?
thanks
Thanks 👍🏼Gas and brake👍
And it stop itself after the prosess
After it cranks for it's set time (A8), then release the accelerator and hit the button again and it will start.Rookie question here....after you floor it, is it as easy as just letting off of the accelerator quickly or do I need to push the button to stop the starter and then proceed to start normally? I'm afraid if I let go of the accelerator the engine will start up at a high rpm at first.
This is actually a good question. I've always wondered what the optimal frequency should be.I'm confused then, where it's a good idea to start, what if it sat 25 years then?
Just fire it right up after that time?
If your engine is fully lubricated after an hour, a month, a year, or multiple years, why would it matter if you start it, or not start it?
That is really what is in question, the frequency.
That's the question, at what frequency is prudent.
I drove mine yesterday but otherwise I keep it on a trickle charger over the winter. I also drop my insurance to just storage insurance except for on the days that I drive it.Question,I put my HC Challenger in storage for the winter.I did all the prep: full tank of fuel with sta-bil,inflated the tires and put it up on ramps(race ready)etc.should I start it and let it run periodically or leave it sit and wait till I get it out in the spring?
Wonder why thieves are so interested in them then. Should be much easier to find Camrys and KIAs to steal.Also, ultimately, it’s just a car
Isn't it a lot easier to just hold the skinny pedal down? It has been for me.To prime- just pull the fuel relay in the trunk by the battery. Then crank it over for a bit, replace the relay and start the car.
Personally, I would rather start it every 2 or 3 weeks and let it run until it reaches operating temp.
I was just thinking “I better grab a Coke and some popcorn….shit is about to get REALLY interesting, REALLY fast!”Oh man can't wait to see the following posts. Should be quite the range of answers...
Yes aside from on first start up it might say “software update would you like to download now?”😞The car doesn't know if it was run yesterday or 4 mo ago.. let it be..I've been storing cars for over 40 years during midwest winters in heated and ambient buildings and have never started any of them until the weather and the roads were good. never had an issue. treat the fuel and a trickle charger or take the battery out.
Very hard well, at least impractical to get the engine fully up to temperature without driving. (As for driving, even a prolonged drive (~10+ miles) did not have my Scat Pack or my Hellcat up to temperature. But what I quickly found with these cars -- courtesy of Performance Pages -- was that both would get up to temperature, and then some, rather quickly just driving in town conditions. And from a dead cold start, too.)So what's the secret to getting the oil up to temp without driving?? Heck, I can barely get it warmed up a lot of times when driving, without going up a somewhat steep and long grade.
Unless by "operating temperature" you mean the relatively meaningless coolant temp.
Still quite enough oil to provide suitable lubrication upon a cold start. "Priming" via the slow cranking of the engine via the starter is actually ill advised. There's a reason the most common startup has the engine spun up to around 1K RPMs right after start. This ensures the creation of the hydrodynamic bearing (created from the oil present) and the quick prime of the oil pump and subsequent rapid flow of oil.Wrong. The longer it sits, the longer the oil has dripped off everything and left mating surfaces.
If priming is not advised then why does it come recommended right from dodge? Lol.Still quite enough oil to provide suitable lubrication upon a cold start. "Priming" via the slow cranking of the engine via the starter is actually ill advised. There's a reason the most common startup has the engine spun up to around 1K RPMs right after start. This ensures the creation of the hydrodynamic bearing (created from the oil present) and the quick prime of the oil pump and subsequent rapid flow of oil.
It’s posted on dodge garage.Well on the priming issue Dodge doesn't say anything on it either way and what we are doing is actually the Flooded Engine procedure listed in the Owner's Manual.
Still think it's not a bad idea coming out of storage.
The article was dated April 2019. If it was so critical why did it take Dodge this long to make this prime operation known? And only after some guy asked about it?If priming is not advised then why does it come recommended right from dodge? Lol.
priming just lets the oil flow around and coat the surfaces before you start the engine. Way was wear for a starter turning the engine “slowly” compared to the engine running immediately. Quick google search says typical starter turns a motor at 200rpm. At idle when you’re running you’re at around 1000rpm.
Id rather have the motor get coated with fresh oil at 200rpm for a few seconds before starting immediately at 1000rpm.
