1 - 18 of 18 Posts
Has anyone used this on their DD HC? There is a specific one for Adaptive Cruise Control but I'm not sure what the difference is? Seems it may be the same frame but just mounted over to the side a bit? Any pics on DD would be great.
· HOTM Winner
Reactions: CRKFIEND
Offset it either way, don't put it right in the middle of the grille opening.
Have one on the wife's Charger. Noticed it had a scrape on the bottom of the mount, but no damage to the fascia. It takes up just a slight amount of clearance, but it was enough that it scraped something.
Discussion Starter · #14 ·
Mounts with existing hardware. Very solid. Adaptive cruise works fine.
View attachment 580548 View attachment 580549 View attachment 580550 View attachment 580551
Unavowed, OK so you go yours mounted off to the side! Is that due to the adaptive cruise? Is the Adaptive Cruse that flat plate I see in the middle of the grill? I've had some that the Adaptive Cruise is the canera on the backside of the rear view camera and that flat plate is nothing. If so, I could get the middle mount as that is what I prefer.
Discussion Starter · #18 ·
So how tight are you guys tightening the bolts on your DDHC? I just installed mine and the instruction say to use a 1/4 ratchet to avoid over tightening and I got them pretty tight but the whole frame moves around quite a bit. I'd say 1/2" up/down. I'm wondering if I tighten it more, will it help or will it strip out? I'm not 100% sure what I'm screwing into. Is it just a threated sleeve or tab? Or is it a full on nut? Let me know how tight you guys are doing it and if you have any play in it. Thx.
1 - 18 of 18 Posts
