1 - 7 of 7 Posts
I have a 2018 charger 392. I need the torque specs for the collector studs where the factory manifolds bolt to the factory mid pipes. I replaced the graphite gasket but it's leaking, I'm thinking I over tightened it.
· HOTY Winner
I think they are only 37ft lbs.... hold on
· HOTY Winner
nope, the band clamps are 37ft lbs after the mid pipes.
the mid pipe to exhaust manifold nuts are 22ft lbs
· HOTY Winner
It is always good to check torque again after a week of driving, but nobody does. I would just go 22 and be done with it. Make sure you tighten them evenly.
Discussion Starter · #6 ·
Ok. I have a wide band sensor right after the collector right before the cat and I put a new gasket on when I welded the bung in but I definitely cranked them down way too tight and probably caused a leak cuz I'm reading lean on the wideband.
· HOTY Winner
Makes sense.
1 - 7 of 7 Posts
