1 - 20 of 29 Posts
2021 Redeye Super Stock
Hey guys. What are some definite mods to help launch and hook on the street? I want to just hook and go better strictly for the fun of it. I have learned to modulate the throttle pretty good on my Super Stock. Just seems like there should be a good way to get more consistent street launches maybe with some additional bolt ons or something. I know there are many variables on the unprepped surfaces of the street. But what can you do to just spin a bit less and hook better? Tires and rims, control arms, diff braces, or what? Looking for the surest, most obvious approaches. Thanks for any and all input.
· HOTY Winner
DR's work fantastic on the street for me.
P4D DIRS Rear Diff Brace
P4D Race Brace
AAD Rear Arms
BMR Cradle Lockout
BMR Diff Lockout
BWoody Short Rear Sway Links
17" Rear Wheels
MT SS DR.
That is great traction for the street.
Discussion Starter · #5 ·
P4D Race Brace
AAD Rear Arms
BMR Cradle Lockout
BMR Diff Lockout
17" Rear Wheels
MT SS DR.
That’s exactly what I was looking for man. Thanks.
2020 SRT Super Stock
I'm the most inconsistent driver I know. These aren't technically legal for street but they sure do grab better for me. They don't rub or touch anywhere and I have a lot of time on them now.
Hoosier D.O.T. DRAG RADIAL 2 P325/45 r 18
I have been subscribed for a bit !! Nice improvments in your 1/8th times
Tazer ZAutomotive now has a brake launch button feature. Similar to the Demon's trans brake, the Tazer can use the steering wheel Aux buttons to hold all 4 brakes with the button instead of the brake pedal. When you release the button, the brakes release.
I have a tazer but it is still locked to my scat pack that I traded in. I can pay $50 to have it unlocked, just curious if you tried this out yet and if its any different than just foot braking the car.
Discussion Starter · #14 ·
Haven’t tried. Looking for more of the best “parts” for launching. But thank you!
‘16 A8 Shaker
I have it and can’t wait til they fix the glitch
Came with update 2.5.3 that was released 2/16
Line lock is still SET+
SET- becomes brake launch
Problem is if you have esc turned off it comes back on soon as you launch. Traction control too obviously
‘16 A8 Shaker
· HOTY Winner
@GreenMachine15 which bmr diff lock out did you go with?
The inserts, the poly, or alum?
I did inserts. Poly will give you some NVR .
Aluminum will definitely give you every bump on the road and NVR.
Reactions: Chancey
‘16 A8 Shaker
Line Font Screenshot Parallel Rectangle
Not worried bout NVR. Especially if she is only 12-14. When they hit 45 or 50 maybe? 🤔
Ok thanks. I am gonna do the inserts. Gathering everything so I can do it in one fell swoop
Not sure if the race brace actually helps hold the housing together? And certainly not without doing alum diff lockout. Doubt dude needs that for street use anyways. Hard to hook on dirty street. Also op R’s get flat spots if you don’t drive daily and won’t last long if you do : )
‘16 A8 Shaker
Also op, I believe there is traction to be had by getting more of this things weight to the rear. Might wanna look into removing rear coil spring top dampener and putting heater hose (search that) or adjustable coil overs etc.
I ended up paying way too much and waiting way too long for what I’m doing with the back of mine but I am gonna bracket race it summit series. Prepped track we race on chemicals. Totally different than asphalt street
Automotive tire Automotive lighting Rectangle Gas Tints and shades
I just paid the $50 to unlock my tazer. This function seems to work 100% better than the factory launch control, well worth it. Can actually boost it past 1200 rpm without breaking the rear tires loose.
1 - 20 of 29 Posts
