This can be done. Try checking Crutchfield. They usually set you up with instructions on how to install what you buy from them.
This can be done. Try checking Crutchfield. They usually set you up with instructions on how to install what you buy from them.hello I wanted to see if anyone was able to install a subwoofer box in the truck and an amp, using the stock head units?
Which stereo do you have in the car?ok so Im confused, do I just tap into my rear speaker's wires for the line converter or run it from the back of the Uconnect radio? Im thinking of doing this myself and possibly adding some sort of sound detonating material to lessen the truck rattles. I have the Alpine system.
Show us a pic of the final install setup OP.
Looks like you drilled into the trunk floor? I have two 12s in my trunk with velcro on the bottom but the box still slides when I launch hard or hit a corner fast. Wondering if i should bolt the box to the floor similar to what you did here
In my old system with the sub box I had, I used some 1" aluminum L stock to attach the box to the "floor". But I did mine on the seat side of the box so you couldn't see the aluminum brackets as you looked at the box from the trunk...Looks like you drilled into the trunk floor? I have two 12s in my trunk with velcro on the bottom but the box still slides when I launch hard or hit a corner fast. Wondering if i should bolt the box to the floor similar to what you did here
gotcha makes sense to me. good suggestions/input guys thanks!yeah it drills into the bottom cover (trunk liner) I used some small L brackets from hardware store that come with small screws. I was facing the same thing, the box would move all over the place. Finally now its sits put.
