I figure with cars mostly using invidual coils for each plug that are, ostensibly, fed by the car's 12-14.4V power, can you just supply a higher primary current to the coils for greater voltage across the spark plug gap?
If the coils are switched in such a way that the primary voltage doesn't directly touch the car's electronics, couldn't you just boost that voltage to the coils to boost output?
Or as a more work-intensive idea, make your own coils by winding them with 2-10 times as much ratio between primary and secondary wire wraps.
I know that there is a point of diminishing returns with more spark energy. But, why not find it? It would be simple to increase the input voltage if it is possible to isolate that from the car's electronics. You could wire the existing ignition timing outputs on each cylinder to instead trigger a transistorized switch that fed the coils with whatever voltage you like, instead.
I have occasionally looked at the drag racing cars with their arc-welder-level magnetos supplying power to the plugs, and cast envying eyes on that power output, and wondered how one could ignite every last molecule in the combustion chambers in a similar fashion. How can you get super-high-spark-energy without resorting to magnetos? Research shows there is some advantage to higher spark energy, if only to make it less likely to get a misfire/mis-spark in a cylinder.
I know that he slight delay in adding yet another electronic switch between the car's brains and the spark coil would need some compensation by one's timing. Are the coils always powered, and then suddenly shut off for each spark, or are they suddenly provided voltage then have the voltage cut as suddenly to provide the delta V needed to provide spark energy?
More spark never caused less power. But how to have more spark, preferably in duration AND intensity? A spark that went on from ignition to exhaust valve opening could not hurt power output, like the old Mallory capacitive-discharge systems, but exaggerated in its event duration.
