1 - 20 of 40 Posts
Demon #422
2022 Super Stock on order.
Of course there are things to research etc.
What should I have waiting for it when it lands?
Stone guards? Keep those drag radials from tearing up the quarters too bad?
Valentine 1 mount and mirror tap?
Jacking rails or subframe connectors? BMR?
Stage 3 ...can't wait to see the details on it.
Extra hood pins and cables?
New to the Challenger front, lots to learn.
The way the tires wear I suspect a spare set of wheels would be good. I like the look of the factory wheels, maybe I'll score some take offs, etc.
D.
· HOTM Winner
ZL1 here. Also the ZL1 side skirts will help protect the doors and the front of the rear flares. They just happen to look awesome too. I did those along with PPF on the flares, front bumper, and door cups. So far so good.
Wheel Tire Car Land vehicle Vehicle
Wheel Tire Car Vehicle Land vehicle
2022 Super Stock
For the owners of the SS and have put the Zl1 rock guards on...anybody got a pic of the fronts. Slowpoke 387 pic is on the Redeye w/ the 305's (nice car). My Redeye looked good w/ the Zl1's but now w/ the 315...I pulled them off after several attempts using the Scotch Mount 30# tape to find a position that would look right. The package was stickered for a widebody and fronts w/ 4-clip locations but they don't even come close to what a rock guard should look like. In the position they were designed for they are canted way too much inward toward the bottom (at least an 1-1/2" off near vertical). Rears look OK. The splitter guard I bought for the SS had the pilot holes drilled on the non-textured side and the holes for the bolts were not drilled thru. Not getting any response from Zl1 so will drill the holes out and see what happens. Also left the splitter guard on the Redeye...that was probably a mistake.
2022 Super Stock
What did you do with your ZR1? Did you get your SS?
Hi Chris...I guess you're talking to me??? I did get the SS, It came in the following Monday (4/11) and I picked up that Tue in Paris KY. On the rock guards after checking to see what another supplier had, I decided which was worse Rock Chips or funny looking Rock Guards. Put the guards back on and w/ the tape on the fender flare flange I kept moving the guard until I got something that I could live with. Clips are tight to the fender flare flange but not the guard cutout in all 4-locations. The tape will help hold them in place. I used tape and clips on the Redeye and it worked so we will see. Put the guards on the rear and they look OK much better than the fronts. Tried to find info on other brands but no luck as of yet so living w/ what I have for now.
2022 Hellraisen SS
what color did you get?
2022 Hellraisen SS
I had the dealer install my rock guards
1 - 20 of 40 Posts
