My SS was delivered with right side tires on drivers side. I believe this is wrong. Just saw a video of another new SS that was done the same way.
Am I missing something here?
Robert
Robert
Guess it leaves Brampton on regular tires and the wheels with the drag radials are swapped at the Upfitter.Who is upfitter?
You'd think, but apparently not. Mine clearly sat out a long time. I had to do some paint correction where bird crap had damaged it. Can't imagine how it would have looked if I'd ordered the satin black hood/roofbottom line.... PEOPLE are probably just stupid installing them. (?)
wouldn't you be proud to work on these type of cars at the upfitter, and take pride in your work?
I am not 100% following you here. So, you have Right side tires on the Drivers side. I get that. But are they rolling the correct direction? Arrows pointing the correct direction dispite being on the drivers side? If that is true, then maybe they were out of left side tires. Maybe it would be 6 more weeks before you got your car, or more. If this is the case then you will have the not as nice sidewall exposed, but should not affect anything.My SS was delivered with right side tires on drivers side. I believe this is wrong. Just saw a video of another new SS that was done the same way.
Robert
Aren't they all the same tire with Right stamped on one side and Left on the other? I haven't had mine off to look at the back sideI am not 100% following you here. So, you have Right side tires on the Drivers side. I get that. But are they rolling the correct direction? Arrows pointing the correct direction dispite being on the drivers side? If that is true, then maybe they were out of left side tires. Maybe it would be 6 more weeks before you got your car, or more. If this is the case then you will have the not as nice sidewall exposed, but should not affect anything.
Robert
Yep, same with my SS.
I noticed it almost immediately while in the process of swapping out the brake pads with Z23's.
Thought I was seeing things !
Apparently I'm not alone.
IMO just an honest mistake, otherwise the car is incredible !!
